Inside door handle
worxriteworxrite Guest Posts: 7
edited March 2016 in Lincoln
We have a new door handle for our Lincoln mkz and
need some instructions on how to take the old one out
& put the new one in.
Your assistance will be greatly appreciated.
Thank you,
Rcorbett
  • texasestexases Member Posts: 11,177
    Which year? I just did it on my 2011 MKZ, I found a couple of Youtube videos that explained it pretty well. You'll need a T20 Torx driver, a socket (I forget which size) and something to help pry off the door panel. You might want to buy a door trim remover, it's made specifically to do that. The one problem I had was uncovering the Torx under the door handle area. The videos showed a small cap that could be pried out, like the other 2, but on the 2011 there's actually a small plastic panel that pops out. Good luck!
  • worxriteworxrite Guest Posts: 7
    Thank you for your response!   It is a 2011.
    Rcorbett
