Bug Removal
                    I know this question has problem been asked and
answered a million times on here . . but I'm kinda
pressed for time. Does anyone have any suggestions
for a good bug removal product. I have a Red
Accord . . and I want to get rid of the bug juice
and guts on it. I also don't want to mess up the
paint job . . .so, what do ya'll recommend?
guitarzan
Community Leader/Vans Conference
a little #1 kerosene to remove tar.Not knowing for sure if I was taking the polish off or not
I always applied another layer of polish on the areas that I removed bugs and tar.I would steer away from any rough or abrasive sponges no matter they are made of.Note:If the water is too hot for your skin it`s too hot for your car.Also letting the kerosene soak into the tar for a couple of minutes makes the removal of tar much easier.
You don`t want to do either on a freshly painted vehicle until the paint has cured.
I discovered what I think is the best method for removing bugs and other debri from the front of my vehicle. A while back, another car splashed up some white paint that had spilled on the roadway up onto the front area of my car. Fortunately it was water based. Anyway, the removal process was quite time consuming. I finally got impatient and went and grabbed the nylon scrub pad I use to clean the pots/pans. I used this in a small area w/lots of water and miracle of miracles, the white paint spots came off! This did not harm the finish at all, and I used it to remove those bugs that get all over the front area in warm weather. I have used this method to keep the front of my car looking good without purchasing any chemicals and the finish has not been compromised and those bugs now have a new enemy - the nylon scrub pad!!
Try it - it works even better than you might think!
Michael J.
those acrylic aquarium tanks. I've been in the reefkeeping hobby for almost five years now and I know this scrubber really works. I keep a seperate
pad for my car/van for taking off those nasty bugs/bird "droppings". They come in pads of different brands and sizes. Just go to any fish/aquarium store and ask for an ACRYLIC tank scrubber (and NOT FOR GLASS TANKS )!!!. Its WHITE in color...
p.s. I think pets r' us has it too
Wax the vehicle well, use a wax that can be layered (Zaino is a premium one, I don't know of cheaper ones that do this) and bugs and tar will remove easily/easier.
Tar remover is great after the fact. Such harsh chemicals shouldn't be necessary if the above is followed.
What's the last thing that goes through a bug's mind when he hits your windshield? His [non-permissible content removed]!
Hey people, I recommend that you stay away from Eagle1 bug and tar remover.
I had a brand new Grand Cherokee with spots of road tar on the vinyl cladding around the lower part of the doors and fenders. I looked at different products for removing the tar, and they all recommended that you do a "test spot" to be sure that the paint wouldn't be damaged. All except Eagle1, that is. They didn't say anything about a test spot, so I figured they must be sure their product wouldn't damage the paint. It said on the can that it was safe for all painted surfaces, so I figured it would be safe on the cladding.
I followed their instructions to the letter, but it took some of the paint everywhere I used it. The cladding was gray, and everywhere I used the Eagle1 the gray was a lighter shade!
tsjay
tsjay
Not sure how it works but it works!
Pat
I was quite impressed with the product. I used it after I first washed and dried the truck. It worked very well. I just squirted a bit on a clean white cloth and applied to the areas where the yucky bug splatter was left. I didn't have to rub very hard at all, it applies easily and actually has a nice citrus smell. It is safe for clear coats. If you are curious please give it a try i'd like to hear what anyone else thinks of this product. I found it at the local PEP BOYS in my area. Thought. After using it on the grill of the truck. I started to wonder whether I could use it on the windshield as well. I will have to try it the next time I wash the truck.
best of luck
plenty of water and car soap did just some of the trick
2-3 hours off buffing, 1/2 of hood stripped from wax and still lots of this stuff left
anything good for egg?
http://autosupermart.com/
