Do I need clutch work?
I have a '94 tercel with 4spd manual, 74,000 miles
on the odo. Feeling the clutch disc is quite thin
because I need to loose the clutch pedal almost
completely before the gear engages, but no slip. Do
I need a clutch work?
Input appreciated.
Input appreciated.
If your hydraulic reservoir is low, that can also be a sign your friction facing is worn thin. If you have to pump the clutch to get it to work sometimes, then it can be the master/slave cylinders are leaking.
So first find out if cable or hydraulic operated.
If cable, there might be some adjustment left. If hydraulic, you probably have some worn parts somewhere.
rubbing/crunching sound (and you can feel some kind of rubbing) when I disengage it. It's a hydraulic clutch, it shouldn't need any adjusting should it? It doesn't affect driving or gear switching (no slippage that I can detect). The clutch master cylinder seems full ..
any thoughts?
-Josh
Our 96 Maxima SE 5-speed does the same thing - it has 60,500 miles. It is likely the throw-out bearing is the culprit for both you and me. However, as far as I know, they don't just up and snap or break, so you can keep driving it as long as it doesn't get too bad and the clutch can be completely disengaged.
But expect throw-out bearing replacement in the future.
What year is your car?
weird ..
If we do have the throw out bearing done, should we have the clutch looked at/replaced while doing it?
We bought an extended warranty and if it doesn't cover the clutch, I don't know if my parents can pay for it...I'm just entering college, graduated from private high school. my brother, 2 years younger is at same private high school. Talk about expensive educations...so money is limited.
I decide not to do the clutch work until it completely gone. My friend's MR2 had a bad throuw-out bearing and the dealer convinced her to have the whole thing changed by the reason that the prices do not have big difference. My tercel now has 76500 miles on the odo. with the original clutch. It will finally get to the point when I have to take $500 out of my pocket for a new clutch.
and a hydraulic clutch. The car vibrates excessively when starting from a dead stop. If I give it a lot of gas, it moves out OK. The problem is manuvering in parking lots or in my drive way. Is this typical of a clutch on a Subaru due to the AWD? I think it may be due to the AWD, more stress on the clutch. This is my first AWD vehicle, is this typical? Is this clutch adjustable?
Do I care for my car? I sometimes call it "Principesa." At least while it's on the powertrain warranty, I want this remedied. I've certainly given them enough chances to find what's wrong, having described ALL the symptoms. Does anyone else have a similar story with a Subaru 5-Speed?
I simply needed to get used to the clutch. I had been driving a Camry 5speed and I think the AWD causes extra drag on the clutch so you need to give it more gas to get moving. Now that I have been driving it five months, I have no problem until I drive my wife's Camry with a 5-speed, it feels a lot different. Sounds like you folks have more serious problems, if mine gets no worse than now, I will be very happy.
Sorry I can't be of more help.
Pat
