Sedona Road Trip Impressions - 2016 Toyota Tacoma Long-Term Road Test
Edmunds.com
Our 2016 Toyota Tacoma took a road trip from Los Angeles to Sedona, Arizona, with Senior Editor Josh Sadlier at the helm. Here are his impressions from the drive, both on-road and off-road.
Mother Nature's grandeur makes use humans look quite tiny.
Nice pics btw
Sedona is a fantastic place to take a 4wd. Funny thing is the perspective of that video makes the terrain seem much tamer than I am sure it really is. I bet it was much steeper than it looks on video.
This is how I feel about moving from our Xterra to our Honda pilot. The 4.0 V6 was just such a torque monster that it moved along so effortlessly where you have to wind the 3.5 out in the Pilot for it to move (at least it sounds great!). Funny thing is that the Pilot really doesn't weigh but a couple hundred pounds more and aero can't be much different. Our Xterra got 19.5 mpg running around town without trying and 16 while towing our tent trailer. our Pilot is lucky to break 18 running around town and gets 12-14 towing the tent trailer. Lots of torque, keeps the RPMs and fuel consumption down!
By the way, that's also why diesels are perfect for trucks, but Toyota doesn't seem to have a U.S.-viable option in that regard. It wasn't that steep right there, but you can see there's some significant wobble and suspension articulation as I'm driving onto that ledge. Having said that, the tourist Jeeps were going faster than I was with about 10 people sitting unprotected in the back, so also consider the likely fact that I am an off-roading wuss.
-JS
One of these days I need to cruise up to Moab.
I owned a CJ-5 for a few years back in '74 and soon learned that having 4WD just means you get stuck further off the pavement. There's no substitute for local knowledge on roads like these.
I'd venture to guess Toyota made switch to the 3.5 from the 4.0 help lower fleet emissions levels, though I'm not sure where to find any data to support a cleaner burning engine theory.
Direct injection isn't worth anything like 50 horsepower. Those big paper gains are primarily a result of the direct injected version going in explicitly sporty or semi premium products where they raise the red line (and use 89 octane besides) for marketing's sake. They can and do pull the same trick with MPFI.
100 bucks of higher specced materials to bump red line to 6500 and put 310 hp on the brochure wouldn't be worth a damn when the problem is gutlessness under 4000 and a transmission programmed to keep you there.
Now, do all of these size engines make those gains, going to DI? No, and I probably should have said it was more like 30-35 hp, but...only 278 hp and 265 lb/ft, at a high 4600 rpm? While they got more torque than in other 3.5L Toyota engines, they didn't lower the torque peak rpm, which I agree is what they needed to do.
