Easy To Refuel - 2016 Toyota Mirai Long-Term Road Test
Fueling the new Toyota Mirai requires a slightly different process than a standard sedan, but it's not complicated.
My question is how does it charge you? I'm guessing it's got some way to calculate the difference in PSI of the customer's tank to figure out how much you actually received. Do they bill you buy the Price per PSI? And I would think that you'd get a better value at a higher PSI than a lower PSI, since there would be more molecules crammed into the same space.
The hood of the Mirai still looks like it's not been attached to the car. That black line that separates the hood and body line is horrible. At best, I think "Someone forgot to shut the hood down."
