Ford's 4.6L motor discussion.
Has anybody experienced "excess wear" on Ford's
4.6L motor? My 93 Lincoln TC has 126000 miles and
is starting to blow smoke after idling at a traffic
signal. Also is using a quart of oil in 1500
miles. Maintenance has been regular (LOF every 5000
miles). Dealer wants to install a new motor for
$3000. Any word from Ford? Any similar experiences?
You can have an independent mechanic install an engine from the scrapyard. Not sure if it is possible, but if it works, a 302 might be a good replacement choice.
guitarzan
Community leader/Vans conference
The car had an easy life. Driven by my wife. No racing and regular service.
Any comments or suggestions?
I don't know if his price for the work is good or not, but it doesn't sound that bad to me. This being an overhead cam engine with 2 banks of cylinders to work on, there's probably a lot of labor involved.
If he does a compression leakdown test he will be able to tell if the cylinders are worn, but as I said I would be surprised if they were.
Dave
Thanks for all your responses and happy motoring.
Sorry to hear that you have engine knock problem with your 4.6l engine. I would strongly recommend going to F150 online web site to look for answer to your problem, as I do remember seeing the same topic posted in one of the topics they have there. Great site with lots of great people, and useful information. Good luck!
Thau
No, I'm not putting it in the radiator. It goes in that box that says "Wiper fluid only" right?
While I was using my T-Bird to jump start my mercury, I came one step closer to a solution, although I have yet to find the time or the $ to take it to a mechanic. Smoke started coming from somewhere behind the left cylinder bank after letting it run at about 2,000 rpm for a couple of minutes. Smoke smells like burnt oil, so now I'm thinking valve cover gasket or head gasket. So now I need to know how much replacing a head gasket on a 4.6l T-Bird can expect to set me back?
I'm just thinking practically, but maybe you have an attachment to your car or consider it to be a restorable classic.
(1998 F-150 w/24k) The knock in my engine did not suppress until the completly warmed up. The new motor is running good! Good Luck.
PS. Your in for some tranny problems. Will feel like your driving over a wash board. Car was just over warranty. Fors wanted to do a tranny job at my expense.
Mechanic pulled me over to side & told me to change fluid & make SURE they dump the torque conveter. They did job & I still had problem. They didn't dump the converter. Took it to Gease Monkey & they flushed the tranny. No more problems. All automatics hve the problem yet FORD will not use a recall. Got so disgusted with it I dumped it.
At this point Ford has agreed to replace the vehicle altogether and consider it a lemon. I took delivery in Oct 1999 and it has 2,300 miles. Is this a common problem in their cars? Should I just get something else? Help?
Good luck and enjoy.
The one on the passenger side is located just after the catalytic convertor. It looks like a spark plug screwed into the exhaust pipe. It can be seen from the top looking down the fire wall where the transmission dip stick is, BUT you will have to take it off from the bottom. Follow the manufactorers instructions as you may have to use an anti-seize compound.
Thanks-Bill
