Cooling Issues
bobmar540bobmar540 Member Posts: 4
edited May 2016 in Mazda
Had several leaks start in heater hose as fix one another start in other hose new clamps,flush system and heater core
water pump has squell in it not all time but often after flush with product start back up no leaks the temp heats up and get steam from weep hole water pump ?????????? Please help
  • texasestexases Member Posts: 11,205
    If steam's coming out the weep hole, the seal is bad and you need a new water pump. You'll also want to do a pressure test once you get the new pump installed.
  • bobmar540bobmar540 Member Posts: 4
    I put radiator cap were pressure could escape and ran fine ? Water Pump ?
