Still Pulls - 2015 Jeep Renegade Trailhawk Long-Term Road Test
Edmunds.com
Our trip to the wheel and tire shop wasn't enough to solve the pulling issue in our 2015 Jeep Renegade.
"With the weight off the tires, and with each of them properly inflated, check their circumference with a tape measure pulled tight around the center of the tire.
You'll probably find that the left tires are bigger - sometimes up to 3/8" - which translates into about 1/8" in diameter. This means the car will tend to pull right. I've seen this many times, even on brand new tires, and some vehicles are particularly sensitive to it.
In the US, you want the 'larger' tires to be on the right side, which helps correct for road crown."
Try it on your fancy lift.
it's a jeep thing, you wouldn't understand.
Well that part is right, when you get beat by something you do need to close your eyes, forget everything you know about it and start over again from the beginning.
Let us know when you try swapping the front tires side to side.
