2014 Mazda CX-5 Grand Touring AWD Long-Term Road Test
I caught my foot on a plastic trim piece in our long-term 2014 Mazda CX-5 and completely dislodged it. It snapped right back into place but its design is less than optimal.
But the bigger issue here is the location of the piece. The footwell area around the pedals is one of the more dangerous spots to have large pieces of plastic floating around. It's simply dangerous. That plastic could get lodged above or below the pedals and cause unintended acceleration or the inability to stop. While this was an easy fix when the car was stopped, it would be a bit different at highways speeds. I think you should report this incident to Mazda because, even if your fix is permanent, it could be a problem if it happens to someone else.
The cabin air filter is actually behind the glovebox trim and wonderfully easy to change:
Everyone is going to want to know why you don't ask the dealer to fix it though. So why don't you?
Guess you tried eBay too. Pretty bad, checked this clips and fasteners site and they have three pages of Mazda clips and none look like the ones in the pic. And the ones they do have aren't cheap. Guess you could chat up a body shop and see if they offer any suggestions.
I'm thinking you might be able to rig up some black zip ties and clip the loose ends close. Or maybe try some double-sided tape, with an especially big piece over the foam square shown in the pic.
Makes my head swim just thinking of trying to rig up something down there.
