Installing the Hidden Trailer Hitch - 2016 Tesla Model X Long-Term Road Test
Edmunds.com
Our Tesla Model X has a trailer hitch, something the Tesla Model S never had. And, like everything else Tesla does, it's fairly unique.
1
other manufacturers (jeep) clearly don't want you towing with their vehicles. they make it optional/expensive and heaven-forbid you want to retrofit one of their vehicles with the OEM receiver for a cleaner look. did that once with a 2005 grand cherokee... never again.
On a side note, if Dan Edmunds doesn't/hasn't used the shared name of the company he works for and his last name to pick up eligible single females, I'm disappointed in him. Unless he's married. I'll give him a pass for fidelity.
Twitter: @Edmunds_Test
As for the range impact on the Tesla Model X, that is a valid point. But, on that same note, due to the nature of the energy draw on the vehicle, they could easily give you a range estimation of different weights being towed under a controlled condition. For example, they could say "with 5,000 lbs, your range would be approximately 150 miles, 10,000 lbs your range would be 90 miles, etc." That's not what they're doing here.
I still think it's not so much an issue of range regarding battery life (so much) but the force applied to the vehicle's unibody with the downward facing 90 degree angle of the Hitch. The trailer's tongue is going to be pushing DOWN, causing the 90 degree elbow to push outward from the top. Now, this is no different than a normal hitch, except that it's typically going into at least a 2x2 or 3x3 square tube. Going down the road though, your hitch is being pulled straight, whereas with this one, the trailer will be pulling on that 90 degree angle, making the top want to tilt forward, towards the front of the vehicle.
And what about the air suspension? How much tongue weight can it support and sustain? I wonder if 500 pounds of tongue weight so far behind the axle is an upper limit there.
Finally, there's aerodynamic drag. Trailers get tall, boxy and flat-fronted over 5,000 pounds. That's the sort of thing that REALLY puts a hurt on consumption and, in this case, range, range, range. I'm dubious.
To circle back to your points about hitch leverage and moments, if Tesla thought the X could tow more than 5,000 pounds for these other reasons, they probably would have nixed the tricky hitch idea and gone straight out the back through a notched bumper like other SUVs.
Do you have to lie down on the ground to do all of this though? The model x has speed, but not much ground clearance, which has been effectively reduced even more by the hitch. I mean, I personally would have my driver do this task, and since the garage floor is lined with diamond quilted cashmere he won't dirty his suit, but what about the average six-figure car owner? Must they lie on the ground like a savage, just to hook up a trailer or bike rack?
On a side note...anyone else realize that the tow rating is less than the specified vehicle weight? It'll tow 5,000 lbs, but a Model X weighs in at 5300 lbs (a little more actually). What this means is...when their BFF with the matching Model X gets high-centered at the local Starbucks on a speedbump, they can't use the other Tesla to pull it over.
I have the hitch installed, and it readily tows a 1,900 lb A-liner hard shell pop up camper. I had brake controller installed stalled in dash, BUT the wiring diagram in on-line manual lacked colors and it is strange. Also no info from telsa on what fuse is affected. Brake controller install failed, and blew fuse and also blew an expensive electronic controller. Which Tesla repaired at their expense, acknowledging lack of documentation. Great service team!
But... Now we find that the trailer lights won't work. Nor will connector on another tesla X. Both vehicles work with a flat bed trailer at the tesla store, but both fail to work with my trailer.
We (tesla mechanic) suspect that there is an electronic controller that recognizes a set level,of resistance before activating power to the 7pin connector... And my all-led trailer draws too little.
Waiting on Telsa engineering to weigh in.
Although getting ready to try adding an incandescent light to the trailer as a test. Or hacking together a connector with a few added resistors.
Ideas welcome.
Btw, needed to add two d-rings to trailer mount, as the small loops provided were-are too small to connect emergency chains to, and also needed to get a few more inches of length as the under-carriage connectors are further from trailer than traditional chain loops on my current Toyota Sienna after-market hitch. I love $5.00 fixes that work well.
PPS. Connector warning... The connector is well hidden under bumper, (vs after market hitches that protrude. Be prepared to crawl underneath to connect power and chains. Use Campsite welcome mat to keep pants clean!
Or as was suggested above, get your personal valet in his model 3 to do it...
