Manual gears aren't working - Compass
Member Posts: 1
edited March 2016 in Jeep
Did anyone else have this problem: replaced transmission haven't even put 3000 miles on this transmission since it was replaced now 1st, 3rd, and 5th gear won't go in. The only gears that are working are 2nd, 4th and reverse. I bought the car almost 10 months ago and ONLY put on 3,000 miles due to the transmission going out on it. Also after getting the new tranny put in cruise cont works only occasionally, ABS and other lights come on when i'm on the highway. I need some input.
  • Member Posts: 118
    Put mine in the shop today for the same shifting problem. We had to replace the flywheel less than 50k miles. (worn out?? never heard of that one, clutch? yes) just a couple of weeks ago $1400 and 3 days to fix. The dealership never had that happen before. Will let you know what happens.
  • Member Posts: 118
    Follow up. Cable connection "fell off". No Charge. Now, after a bump up the ABS and Traction Control lights are on. ARG!!!
X
