Awkward Conversations - 2015 Acura TLX SH-AWD Long-Term Road Test
edited December 2015 in Acura
imageAwkward Conversations - 2015 Acura TLX SH-AWD Long-Term Road Test
The problem is real: Edmunds' long-term 2015 Acura TLX SH-AWD with the 3.5 V6 is plagued with a poorly calibrated nine-speed automatic transmission.
  • agentorangeagentorange Member Posts: 893
    What does it take for you to go to the Acura dealer and tell them the transmission is broken? Two seconds of SFA when you hit the throttle? Really? Sure, that particular occurrence is probably difficult to replicate, but the 2-3 hard shift should be easy to demonstrate.
  • kirkhilles1kirkhilles1 Member Posts: 863
    Agreed. Have you researched it to see if there is a fix? You guys just had at the dealership a few weeks ago. Why didn't you bring it up? At least get a semi-official response from the dealership.
  • guargumguargum Member Posts: 2
    I recently drove a TLX V6 for almost 2 weeks and I can't see why so many people have a problem with it. I did notice some of the odd behaviors described here but it was extremely minimal and outweighed by the the positive aspects of the drivetrain.
  • darexdarex Member Posts: 187
    Can you shift into reverse eyes-free? Seems like such an intuitively bad idea to replace a lever with buttons.
  • thecardoc3thecardoc3 Member Posts: 5,848
    The readers might be interested in seeing just what trying to solve problems is like for today's technicians. If someone is willing to put forth the effort the first step to be taken is here
    http://www.nastf.org/i4a/pages/index.cfm?pageid=3823
    You will need a compatible pass through device of which some will be able to be used for this same purpose with a number of manufacturers. This is the Honda pass through tool.
    https://honda.snapon.com/HondaAcura/ItemDetail.aspx?ItemId=53561297
    There are some J2534 tools that can run O.E. software, but they are not all created equally so there are risks that must be assumed by the purchaser. The 2015 Acura software "might" run on a CarDAQ Plus.
    Once you have the MVCI you can then get a short term subscription for the Acura HDS scan tool. Being that this is somewhat repeatable, you might get away with just the one day subscription. Then, drive the car and capture the data during one or more of these events. Upload screen captures of the data in a graphical format with flags denoting the event. You will need both PCM as well as TCM data if they are separate PID groups.
    Then we can let the sleuthing begin and see how the group does when faced with this kind of data.
    If they took it to the dealership the service department will just say that the transmission is performing normally because there are no trouble codes stored in the computer.
  • schen72schen72 Member Posts: 433
    I've read on the Acura forums that people are having issues with the 9-speed. I would personally stay away from it until the kinks are worked out.
  • cube1uscube1us Member Posts: 5
    I test drove a 2016 TLX *THREE* times trying to decide if I could live with the behavior of the 9 speed ZF transmission, and the answer has been no. I don't think it is just "kinks" either - the ZF 9HP has been around for more than 2 years - plenty of time to work out kinks - and some mfgs have reportedly already thrown in the towel on it. I want all of the safety capabilities of the Advance package, and I'd love to have SH-AWD, and my 2009 TSX has spoiled me, acceleration wise. I am just hoping they come up with a suitable solution for me in the 2017 model, or it will be the end of a 30 year Honda/Acura relationship. ;(
