Full Charge Means No Regenerative Braking - 2016 Tesla Model X Long-Term Road Test
edited July 2016 in Tesla
imageFull Charge Means No Regenerative Braking - 2016 Tesla Model X Long-Term Road Test
Turns out the regenerative braking system in our long-term 2016 Tesla Model X isn't always on. A full charge means there's basically no regen effect.
  • kirkhilles1kirkhilles1 Member Posts: 863
    Interesting. I would think they would want the experience of braking to be the same no matter whether you had a full charge or near empty even if that meant discarding that electricity. Maybe discarding it is the problem...
  • longtimelurkerlongtimelurker Member Posts: 455
    Holy crap is that an oversight. You change the vehicle's coasting and braking performance based upon the amount of vehicle range - ? That's nuts.
  • texasestexases Member Posts: 11,212
    If the battery's full there's no place to put the regen electricity. And adding an extra device would cost $ and pounds.
  • thecardoc3thecardoc3 Member Posts: 5,870
    No that's normal. Even the hybrids have to start relying solely on the mechanical brakes once the battery reaches a certain state of charge. Toyota hybrids use "B" mode on the shifter for mountain braking to create an engine braking condition to assist the mechanical brakes when the hybrid system regenerative braking has to shut down.
  • legacygtlegacygt Member Posts: 599
    On the list of drawbacks of electric powertrains I would say this is pretty low on the list but it's real. Having the state of charge contribute to a significant change n the way a car drives is annoying and potentially dangerous. Maybe they could add some dynamic aero to make up for the fact that there's no regen or engine breaking available.
  • yellowbalyellowbal Member Posts: 234
    This doesn't even seem like a hard problem to solve... dump the excess electricity to resistors and keep the brake feel the same.
    We're talking HUGE resistors. Why spend the $$ when all one has to do is press on the brake pedal?
  • lmbvettelmbvette Member Posts: 93
    This surely is a design oversight.
    I have a Chevy Volt. Granted, the Volt is not a one-pedal driving experience, but it coasts like a normal car when in "D". However, if you put the vehicle in "L" it is 70% of what a one-pedal would be, and the brakes work the same. The brakes work the same whether I have a full charge, in Mountain Mode or zero charge running on gas regardless of "D" or "L".
    Don't worry about what other people think. Drive what makes you happy.
    OK, so when that condition is reached, does that engine braking profile cut in automatically or what?
    edited July 2016
    Because the driving feel should not fluctuate when the battery is full or not. Plus the Model X is not an economy car.
  • 5vzfe5vzfe Member Posts: 161
    I'm sure other automakers employ something similar, but Honda's hybrid system avoids that scenario by diverting excess regenerative energy to the engine bay (in "B mode", after the batteries are full), where the electric motor creates friction by manually spinning the gasoline motor, and voila, engine braking. Again, not sure if other automakers have been doing this already, and it doesn't help the Tesla, but I thought that was a pretty clever solution to avoid braking inconsistencies.
  • kyolmlkyolml Member Posts: 37
    what? you charge the battery to full? it's going to degrade the battery every time 100% charge. Mostly just 90% charge per Tesla suggestion. Don't buy this X when edmunds done with it
  • gslippygslippy Member Posts: 514
    My former 12 Leaf did exactly the same thing - it's normal.
    The Volt is different because the battery never completely drains or fills. "Empty" is something like 25%, and "Full" is something like 75%, so Chevy has the luxury of maintaining the same regenerative braking feel no matter what. Plus, keeping the battery in this narrow state of charge greatly extends its life.
    No, the driver has to use the shift lever to go into "B" mode. http://www.toyotanation.com/forum/105-camry-hybrid/415634-b-mode.html
  • metalmaniametalmania Member Posts: 167
    Maybe they could just put some kind of warning light in the dash that the regenerative braking isn't in use until the battery drains to the appropriate level. I don't like the idea of the car's driving dynamics being variable like that, especially if there was a possibility of someone else driving the car that doesn't do it every day.
    The difference is noticeable, but not alarming. The variable is how hard you push the brake pedal, that's all. With regen not helping, an EV stops just like any other car.
    And, it should be noted that regen is restored very soon after starting a journey with a full battery, because the battery's depletion means it now has room for that regen energy to go.
