hi.im trying to find a chassis wiring diagram for my 2000 honda passport mid-year.
tcooke64tcooke64 Member Posts: 5
edited July 2016 in Honda
the colors are different in the Haynes book. the only thing I can think of is its a mid year. I have installed a new transmission and I have no problem figuring out the 4l30-e internal wiring but need to know what is what on my harness. the colors are as follows on my harness. on the front case I have brown/yellow, brown/white, brown/red, brown/black. the other 6 wires on the main case are, green, brown/white, brown/yellow, red/white, red/black, green/red. I need to know for pin location to connect to transmission. thanks for any help out there.
Answers
    Could try bbbind.com. Free wiring diagrams there when you register.
  • tcooke64tcooke64 Member Posts: 5
    they didn't have it.
    its a mid-year and I think that's why its not there. thank you for the site though.
    edited July 2016
    Probably will get the same result but AutoZone also has free wiring diagrams.
    Lots of public libraries offer access to Chiltons and other online auto repair sites. Well, Chilton's won't be any better than Haynes, but there's another one out there that I used to have access to before I moved - Auto Repair Reference Guide or something like that.
    Oh, and don't forget to do the same search for the Isuzu Rodeo twin.
    Any Passport/Rodeo owners lurking?
  • thecardoc3thecardoc3 Member Posts: 5,876
    When you can't find the right information in the aftermarket, the next choice is the manufacturers website. https://techinfo.honda.com/rjanisis/logon.asp
    thank for the info. so far no go but i havnt been to the library yet guess i need to try that. thanks to all and if you here anything else please let me know.
    well a week later and still no info im lost.
    edited August 2016
    Well, you can find factory manuals on eBay. Best ask the seller's first whether they come with wiring diagrams. Here's an example for $24 but it's the wrong year. This one is $80 but seems closer to what you are looking for since it's specifically wiring.
    edited August 2016
    I went up and down a year, and cross checked the Rodeo schematic. There are almost no changes at the transmission end of the harness, but the control module does change and that causes pin ID changes there. This is what Mitchell on Demand shows for the solenoid pack to the PCM.
    You'll notice that while some of the colors match, they are in the wrong connectors according to your description.
    Try using the PCM wiring harness schematic to identify the wires there and see what they are and then cross reference back to the solenoid pack.
