Ford Escape Hybrid Suspension/Steering Problems
Discuss Escape Hybrid suspension/steering problems here.
Also, whenever I drive on uneven roads, the steering wheel feels very unstable and sensitive compared to the regular power steering wheel. Is this because that it is electric-assisted power steering wheel?
If anyone knows about these two situations, please let me know.
We generally like the car but have noticed the steering is stiff when making minor direction corrections while driving straight on the hiway. We took it to the dealer and got the same run around others have mentioned. I did call the Ford customer satisfaction 800 number to no avail.
Has anyone else notice this or am I wrong is believing that it should at lease steer as easy on the highway as my motorhome does? Around town, at low speed, it steers wonderfully.
Second thing that started the first winter was the occasional power steering failure. The tool light would come on and the instruction to seek maint. It would stay on and the power steering would not come back on. Sometimes it would be off a few mintues / other times it would stay off longer. The problem was worse in the cold mornings when it was near 0 degrees. By the time I would get to the dealership it would start working. The problem began getting worse and I almost had an accident three weeks ago when it went out. Ford response was oh well cant find it it must not be happening so they were not going to go any further. I ask what about my warranty? They siad they could keep my car for a week to watch-without a loaner of course. That was the last straw. I will never buy another ford product. I went and sold it that say day . It was a great SUV but such bad customer service. I hope noone else has the same problems.
Check into it with people you know. All dealers are definately not the same. I use to work at a dealership where the line was "is that your signature? well congratulations, you are an owner and its not my problem." Now I work at a dealership that bends over backwards to make sure we help everybody to the extent we can.
Mark
I just had similar issues but with my electric power assist steering...on my FEH 2008!!!!!
After hearing a small ''tick'' around the instrument cluster, the yellow wrench came on randomly and I was loosing the power steering. It happened to me numerous times, even while turning at a light... with oncoming traffic. :surprise: After manifesting itself for 2-3 days at the time, the problem went away every time I went to the dealer, so no codes were generated for diagnostic :mad: . Only on my 4th visit to the dealer were the techs able to see what was the problem. However, it generated a code which did not allow them to pinpoint the problem. In the end, the whole EPAS was replaced under warranty.
I love my FEH but I think this situation is unacceptable for such a new vehicle. I hate to say this but I lost confidence in my vehicle’s dependability.
:lemon: ... Hope not...
It was kind of hairy trying to maneuver the Escape out of a parking lot with very little steering available. At highway speeds the steering wasn't a big issue.
I took the vehicle to the dealer and they could find nothing wrong. I was told that there weren't any unusual events recorded on the computer. When talking to me they seemed to be amazed that there wasn't any power steering fluid to blame the problem on. Next time it happened I was to bring it to the dealer immediately. Good luck on that since it happens at night away from home.
I've had to have the brake control module and right front ABS speed sensor replaced under warranty. Other than that my '05 is a great vehicle.
And when I say lock up, I mean lock up ... like when the car is off, you take the key out, and the wheel literally locks. That type of lock up.
I'm curious if anyone out there has also seen this. I have an '09 FEH Limited, 20k miles, 4WD, no nav.
Have you resolved this yet?
It's enough to almost give me a heart attack. It's only happened twice in 26,000 miles. But if it catches me on a curve on one of these fast, two lane roads, I'll be off a hillside.
No response from NHTSB concern that I submitted many months ago. I honestly haven't even taken it to the dealer. Can't reproduce it. No warning lights. So I seriously doubt they could shed any light on anything.
Keep us up to date on this one for sure!
Will keep you posted.
The roll stability control system could go awry. A sensor could be misbehaving and indicating a condition that doesn't really exist ... except the RSC system doesn't know that the sensor is wrong. That would be one instance where the 'safe' condition is to take over and/or limit steering from the driver.
I don't give that as a fail-safe mechanism though, because that's not exactly. A sensor failing in a safety-critical system would hopefully be periodically tested for correct operation and throw a warning if it were failing. Or if it fails instantaneously during use, the computer should assume the most un-safe condition and act accordingly. That would be fail-safe.
If some sensor shows a wrong condition in an RSC system, what is the safe condition? To allow steering and let the person flip the truck (as it thinks it will), or not allow steering and prevent the over-correction by the driver?
This would explain a bit why the brake has an effect in resolving the issue. And I've never felt like I've come even close to roll over at all, but my two instances have been going 25-40 into and out of turns.
I don't know. I've been trying to just keep my speeds low on those roads to hopefully alleviate the problem and give myself time to react if it should happen again.
I'm know very little about what cars do for safety. From my experience with trains though, things are designed to what people think is safe, but there's no guarantee their analysis is correct or all corner cases have been covered. I've seen the fallout of a few train accidents that occurred because fail-safe systems didn't behave as such because some conditions occurred that no one ever thought of or tested to.
Also, many systems on cars a important and safety related, but are not fail-safe. Like your brakes. On a train, the brakes are normally on. If power goes out, the air lines blow, or whatever, the brakes go on. You need power and air pressure to open the brakes.
On a car, it's the opposite. You need power and brake line pressure to activate the brakes. If you lose brake line pressure and/or power, you lose you brakes.
So if the steering is fail-safe, it could definitely command a condition you don't want in your case ... and that's if it's even fail-safe at all.
So now I suppose we just wait and see if the problem recurs!
I will be writing letters to the dealership and Ford so they are both aware of the issue so there is no denial later on. I also saw there was another complaint to the NHTSA about a similar problem . We were warned not to buy a Ford because the perception is they do not stand behind their product. We have been over the moon with the Escape until now and I was even thinking about getting aa new F150 but I may have to re-think that decision. I will keep you posted on what the dealer says but they can`t even look at it until Monday and it`s Saturday.
I was going about 20 mph, into a curve. And this time my wife was with me. Again, I applied the brake, and the wheel loosened up.
Taking it in next week, so we'll see what they say. I'm definitely printed out some posts from on here and other sites from other people so they don't discount me as crazy.
They just took me at my word and said, "It looks like Ford has been having problems with the steering column in these Escapes." Though they didn't mention any tests or having seen anything awry.
There's a chance that could fix it. There's a chance it won't fix anything. There's a chance it could actually make the problem worse or more frequent.
I guess I won't know until it happens again. The steering locks up only about every 5000 - 10000 miles, so I need to go at least a year without it happening before I feel comfortable.
I would like to get rid of the car. I'm not too comfortable with driving my family around in this thing. But I don't know if I can afford to do that because I don't know if I can get a replacement vehicle for the same cost as just keeping this one. Still owe $17k on something that might kill me.
Good times.
I want to take it in, but like many posts here, I tried to recreate what happenend today, but couldn't, so there isn't much that can be done. Any suggestions?????
I own a 2006 FEH.
Unfortunately the power steering assist mechanism (electric -not hydraulic) needs to be replaced/repaired.
I am looking for a top flight mechanic who is familiar with this issue, the dealer has recommended that I buy a new vehicle..... they indicate the repair is too complex, risky and expensive.
I would greatly appreciate any assitance
Thank you,
Creta
Did he give you an estimate?
A year and 8 months later, the steering problem returned. this time the dealership had my car for nearly 2 months because they were replacing the entire wire harness and it was backordered.
6 months and 8 days later, the steering problem returned, AGAIN. This time Ford is doing a "repurchase" of my car. They have to follow certain guidelines according to California Lemon laws, they just don't have to follow them fast.
I have been driving this ticking time-bomb since August 20, 2011. I am going to give them about another week to make good with their buyback before I hire an attorney and go that route.
If your steering is going out, you need to contact Ford Corporate. Their phone number is on the internet. Ford knows this is a problem. They are responsible to make it right.
Can someone please tell me the status of the intermittent steering lock up on the Escape hybrid? I have a 2008 and it has locked up twice. On mine it occurs when I need to turn to go around a curve. The steering just straightens out on it's own and makes it very hard to turn for the curve.
I would really like to hear from someone who has had this problem fixed to learn what the cause is and how to approach Ford to get it resolved. Thanks, Black Pearl FEH
I had the problem happen three times on my 2008 AWD FEH, always at slow speed when turning left. The steering simply stopped working for about two seconds. A long two seconds, since invariably traffic was approaching as I pulled out and accelerated to make the left turn.
Ford replaced the steering column and so far the problem has not come back. However the car also generally turns about 2 ft wider in the turn radius, making it a bit harder to swing a "U Turn". However, I like the fact that they seem to have made the highway speed steering a bit less sensitive at the same time. The car drives differently now. It was under my extended warranty, so I don't know what it would cost.
The fact that Ford changed the way the steering works tells me that there is some design problem when the wheel is suddenly spun all the way left while accelerating (but it does not happen often). I've not heard of a recall. I've seen reports of the problem mostly on 2008 and 2009 FEH models.
EDIT: BTW, I discovered the second time it happened that it was actually a power failure - my ScanGuage 2 power reset itself briefly. This makes me think it is electrical, not mechanical. I didn't notice the other times because I was too busy concentrating on avoiding crashing into something.
Thanks for replying Steve. I think a huge challenge is that the problem is so intermittent it's hard to know if it's really fixed. Your story is the first one to suggest that the entire steering has changed so maybe we can have some confidence in it!
I am going in tomorrow with printouts of all the folks who have had the problem and will let you know what happens with Ford. Black pearl FEH
I wonder, if you ever had any further issues or if you fixed it. If the latter, please, what is/was the problem and/or how did you fix it? This is for my daughter while she is away at school. I feel it is still safe but this is nagging me. Please respond. Thankyou.
