Quiet When You Need It - 2016 Chevrolet Volt
Edmunds.comEdmunds.com Member, Administrator, Moderator Posts: 10,138
edited August 2016 in Chevrolet
imageQuiet When You Need It - 2016 Chevrolet Volt
Smart silencing of the climate control in the Edmunds long-term 2016 Chevrolet Volt.
  • kirkhilles1kirkhilles1 Member Posts: 863
    Really? Your 16 Civic does the same thing when you press the voice prompt or touch the mic or have Google/Siri read you the message.
  • iamthestigiamthestig Philadelphia, PAMember Posts: 85
    I'm not a fan of a feature like this -- when it's hot, I want lots of air flow. This is especially true in the 95-degree, 92% humidity days that we often have in the Philly area in July and August. I'll gladly turn up the volume or repeat a voice prompt instead of roasting in heat for even a few seconds.
  • snipenetsnipenet Member Posts: 11
    does turning up the volume also crank up the fan speed?
  • willin58willin58 Member Posts: 38
    I believe this has been a feature on GM models with both automatic climate control and bluetooth for a few years. My '12 CTS wagon does it as well as my parents' '14 Impala so it's nothing new from the GM side of things.
  • mfennellmfennell Member Posts: 91
    The original Volt did it too.
  • lmbvettelmbvette South FloridaMember Posts: 93
    ^^^ mfennell is correct. The 2011-2015 Volt has this same feature.
    Don't worry about what other people think. Drive what makes you happy.
  • oachalonoachalon Member Posts: 12
    edited August 2016
    GM has had this for years. My 2007 Saturn Aura had it, and so does my ATS.
