1996 blazer s10 service engine light on, have changed everything even the computer. Hard shift at 52
beasley5beasley5 Member Posts: 1
edited August 2016 in Chevrolet
Answers
  • thecardoc3thecardoc3 Member Posts: 5,862
    I can't tell you how many times someone just wants a answer like this, the problem is that it doesn't work that way. What happened to one car doesn't really associate to a second one even if the symptoms are identical. Every vehicle problem needs to be analyzed with a disciplined routine otherwise you end up tossing a bunch of parts at it with no guarantee of success. In the shop I wouldn't even want to know what has already been done, especially because without proper testing and just swapping parts you may have even added problems to the car instead of getting closer to fixing it.
    So starting at the beginning like its never been touched, what code(s) is(are) setting?
