Problems with Geo Prizm; Rough idling and misc. issues?
Hello, so I've been having trouble with my car, a 1990 Geo Prizm with about 152,000 miles on it. There's a lot of weird things happening and I'm not sure if they're all related or not. First off, my car idles really rough, but only sometimes, usually at night, it seems. I've noticed that when it's idling rough, it gets worse if the lights are on and better if they're off, but still noticeable. In the daytime, it seems to run/idle fine. Either way, as soon as a I start accelerating, the shaking goes away. That's the first issue. Another one, after running the car for a while, maybe 15-45 mins, the oil light starts flickering in idle. It only flickers when I'm idling in drive, but goes away in neutral/park or when I accelerate. I just changed the oil maybe a week ago, and I didn't notice the light before the oil change. (Maybe I did something wrong?) Another issue, after the car has been sitting for a while, like overnight, when I start it up, a cloud of white smoke/steam comes out of the tailpipe. It's not a whole lot of smoke, but it's noticeable and doesn't smell like anything.
So those are the main issues. I've tried trouble shooting the problem myself, but no luck so far. I replaced the O2 Sensor, changed the oil and oil filter, changed the air filter, replaced the rotor and ordered a distributor cap. The spark plugs look good, but I'm planning on replacing those along with the wires soon.
My ideas were that maybe the alternator was having an issue. (Because of the headlights making idling worse) Or maybe a battery issue, but I've tried different batteries with no difference. Possibly an electrical short somewhere which seems unlikely to me but I'm not a professional. I was thinking from the smoke maybe there's a coolant leak that might be related to the bad oil pressure because of a blown gasket or something.
That's all I've got. I'm 17 and don't have a ton of money to take it to a shop to be looked at, so some advice would be very helpful. Thanks in advance!
Answers
If the engine doesn't stumble or stall on this test, the EGR system is faulty. Clogged valve, or intake airway behind valve, bad solenoid, or leaking vacuum line. Let me know how it turns out and good luck!
