Trouble Starting Up Honda Accord 2006
I recently bought a 2006 Honda Accord ~142K miles. It had no issues until a couple of weeks after purchase. I hadn't driven the car for about 3 days and when I went to start it up, the car would not start. I thought it might be a problem with the battery, so I cleaned the slightly corroded electrodes and jump started the car for about 2-3 minutes, after which it started right up. Now, I just came back from a month vacation, and same problem occurred. I made sure the battery connection was good, jump started the car for a good 30 minutes (to no avail), even put another brand new battery in the car... it's not starting up. I don't think it is a battery problem, as my battery starts other cars right up, and tested good voltage at the mechanic. The starter turns over for 1-2 seconds after each jump start, then every consecutive time after that, when i try to turn on the key, there is a clicking noise and the starter does not turn over. I suspect there is a bad battery connection, as the + electrode was badly corroded, but then I'm confused as to why the internal lights/windows/headlights work perfectly after jump starting. It's just the car that would not start up... Thank you for any help
tl;dr: car doesnt start, battery is good, starter turns over for 1-2 sec after each jump start, internal lights and headlights work after each jump start. slightly loose/corroded + electrode.
Best regards
Best regards
Answers
TYPICAL ACCESSORY CURRENT DRAW (AMPS)
Lights
Headlights (high beam) 10-22
Headlights (low beam) 40
Tail Lights 8
Safety
Emergency brake light 4
Emergency flasher 15
Turn signals 10-15
Windshield wipers 6-20
Horn 15
Brake lights 15-20
Running lights 8
Ignition
Winter starting 225-500
Summer starting 100-400
Approx. Avg. 300
Courtesy
Cigarette lighter 15-20
Interior lights 10-15
Instrument panel lights 4
Entertainment
Radio 10
Stereo Tape 10
Electric antenna 20
Comfort
Air conditioner 10
Heater 20-30
Defroster 15-30
Electric seat 20
Electric windows 20-30
From the Helms manual the starter specs
Starter Motor Current Draw under Manual Load and Temperature - 130-220 Amps
Starter Motor Normal Engine Cranking Speed - 140-220 RPM
Starter Motor Minimum Stall Torque @ 5 Volts - 14.7 N-m (11.0 Lb-Ft)
Maximum Load - 800 Amps
No Load - 60-80 Amps
Maximum Starting Circuit Voltage Drop (Battery Positive Terminal to Starter Terminal) at Normal Range - 0.5 Volt.
Hope this helps and good luck to you...
I appreciate your detailed response! I thoroughly cleaned the battery posts and even replaced the "ring" that attaches to the positive terminal of the battery. It turned out that this wasn't the problem, so I decided to go deeper and actually replace the starter itself. Found out this was the cause of my distress. Although it took quite a while (~5 hours), the car now starts up perfectly with the new starter installed. Once again, thank you for the advice!!
