Setting Fuel Economy Records in August - 2016 Mazda MX-5 Miata Convertible Long-Term Road Test
Edmunds.com
Edmunds conducts a long-term test of a 2016 Mazda MX-5 Miata and reports on its fuel economy for the month of August.
The. Car. Weighs. Only. 2,400. Pounds. And the aerodynamic cross-section is negligible. ANY modern four-cylinder from anyone, in that car, will do the same.
The Civic weighs 700 pounds more and has more power. It's getting almost 3 mpg better than the Miata. However can it do that without SkyActiv? Hmmm...
http://www.edmunds.com/volkswagen/golf/2016/hatchback/rating/
3: Just because cars like the Civic use technology that allows for impressive performance and fuel economy at the same time, doesn't mean the Miata can't also posses such virtues.
You keep harping that the Miata only weighs 2,400 pounds as if that's some kind of cheating mechanism or something that negates it as a good car. I see it the other way around. It's lightweight and good. They aren't mutually exclusive.
And yeah, the car only weighs 2400 lbs. So what's the new Civics excuse? Wasn't that one of the reasons civics were the main car of the import craze of the 1990s? IIRC those hatchbacks only weighed about 2400 lbs too.
And no, I don't think any 4 cyl could do that. Look at the Fiat 124. It's got a turbo 4. It's got more power. It's also heavier, slower, and gets worse mpg.
Except that in real-world use, with drivers asking for both fuel economy and performance at various times, over almost 14,000 miles, the Civic is getting almost 3 mpg better fuel economy than the Miata. You miss that?
The Fiasler 1.4T is a crappy engine.
But especially when compared against the last generation MX-5, which only weighed ~150 lbs more. This ND gets significantly better MPG and faster 0-60. And what makes that big difference, you ask? Not just the 150 lbs, it's the direct injection, higher compression, more aggressive engine timing and management, and lower internal friction. That's what Skyactive is to Mazda. So yeah, fuel economy and performance improves can absolutely be attributed to their Skyactive branded improvements.
Also, gearing/transmission plays a big role. A Civic with a CVT tuned for fuel economy is rated 35 mpg combined (31/42 EPA). Same car with a manual gets is rated 31 mpg combined (27/40).
The Mazda 3 with essentially the same engine as the Miata and a manual is rated 33 combined (29/41) and 34 combined (30/41) with an auto. The Miata is rated 30 combined (27/34). The 3 is also 200 lbs heavier than a Civic.
Clearly, if you put the Civic 1.5T engine in a Miata with a performance oriented tune and a manual transmission (+ stickier tires, rwd drivetrain loss, etc), it will probably get the same mileage as the SkyActive. Many 4 cylinder cannot match it. If you want an apples to apples comparison, compare the same engine in similar cars. Sports cars are not tuned for efficiency as the primary goal, just look at the fuel economy on a pre-SkyActive Miata for example...21//28. That is actually something to complain about.
