No Nav? No Problem! - 2016 Mazda MX-5 Miata Convertible Long-Term Road Test
edited October 2016 in Mazda
imageNo Nav? No Problem! - 2016 Mazda MX-5 Miata Convertible Long-Term Road Test
Our 2016 Mazda MX-5 Miata is the Club, a model that doesn't come with navigation but can be outfitted with it at any time in short order.
  • longtimelurkerlongtimelurker Member Posts: 455
    Ok, except that now you don't have an SD card slot you can use for anything else.
  • kirkhilles1kirkhilles1 Member Posts: 863
    That's a lot of money... BUT, if you think of it basically being a factory upgrade (minus use of the SD Card for anything else), $300-$400 isn't awful especially in comparison to mounting your phone to the windshield of your $30,000 car.
  • craigistcraigist Member Posts: 29
    edited October 2016
    The SD card slot has no other use besides navigation.
    Edit: Actually, it's also used for updating the system firmware. Usually done at the dealer, but it can be DIY'd if you're willing to put in the effort of finding and installing the software.
  • desmoliciousdesmolicious Member Posts: 671
    Very cool. So it took you longer to write up this LT entry than install the nav upgrade!
  • actualsizeactualsize Member Posts: 451
    Yes, Desmo, that is 1000% correct!
    Twitter: @Edmunds_Test
