Saturn Outlook Power Steering locks up in turns
I have had my power steering system lock up on me four times now. The other day I pulled into a parking lot, and could not turn into the parking spot I wanted to park in because the power steering locked up. I had to drive past and fight the steering wheel just to safely park somewhere else almost hitting other parked cars. I have told my wife and daughter not to drive my car anymore until this problem is fixed with concerns of a major accident with loss of control. I don't see this subject on this website, but have seem others with similar problem. Any good info available?
Did the steering "freeze" or did it just become really difficult to turn? Freezing would imply that it locked up, but what it sounds like is that the power assist "disappeared". Did you get a warning light along with the hard to turn sensation?
I found something about a steering issue with the Saturn Ion that talks about replacing the electric motor
I assume the Outlook is going to be using a similar power steering system. Could be that the pump system is failing under stress. Also should check the power steering fluid. A leak is a possibility too.
