2003 Chevy Tahoe climate control sensor
boppascottboppascott Member Posts: 42
edited February 2017 in Chevrolet
I keep having to replace my tahoes climate control sensors because the fans get noisy. What would happen if I either cut the wires to them or spliced them together...Thank-You
  • thecardoc3thecardoc3 Member Posts: 5,877
    Not following you here. Are you concerned about the blower fan making noise? As far as what you are referring to as a sensor could you be more specific? Are you maybe referring to the blower resistor? Cutting, splicing wires trying to eliminate anything would be a bad idea.
  • boppascottboppascott Member Posts: 42
    edited March 2017
    @thecardoc3 the sensor in the rear headliner that send intel to the climate control
    thank you
