2008 HHR WILL ROLL BUT WILL NOT START
ann82973ann82973 Member Posts: 2
edited March 2017 in Chevrolet
I have recently purchased a 2008 HHR with 2.2 Echotech, 96,000 miles. I have replaced the crank shaft sensor, cam shaft sensor, timing chain and water pump. It ran real good for about 3,000 miles. Now it will not start, but rolls fine. i get the codes for cam/crank sensors, but I have already changed them, and the crank shaft sensor i changed a second time. Any suggestions on what the issue could be? I have also tried a small shot of starting fluid, but still no fire. HELP!!!!!!
  • ann82973ann82973 Member Posts: 2
    Well, found out the sheer pins on the cam shaft gear sheared off, therefore, engine died instantly. This was a completely new timing chain set from Summit.. I only got 3,000 miles on it, glad it is lifetime guaranteed. Just hoping for no other damage.
