2007 Toyota Highalnder Low beams do NOT work but high beams DO work. Whats wrong?!?!
josh5mjosh5m Member Posts: 7
edited May 2017 in Toyota
I search online and couldn't find a fix. Could both bulbs really go out at once? The low and high beams both worked yesterday fine but tonight i turned the low beams on, so i thought and they didn't turn on. What could be the issue? Which fuse and where is the fuse located at?
Answers
  • typesixtypesix Member Posts: 321
    Yes, it is possible for both to go at the same time, especially if you do a lot of night driving. It has happened to people I know.
