Performance Tested - 2017 Honda Ridgeline Long-Term Road Test
edited June 2017 in Honda
imagePerformance Tested - 2017 Honda Ridgeline Long-Term Road Test
The 2017 Honda Ridgeline bursts back onto the scene after an extended hiatus. We took it to our test track to see how it sizes up against other competitors in the midsize truck market.
  • legacygtlegacygt Member Posts: 599
    I'm not sure where the weight is but I believe the Ridgeline is actually heavier than the Pilot. Maybe having the rear glass between the wheels rather than over the rear bumper helps handling.
  • Hey @legacygt
    According to our track sheet from our Long Term (2016) Honda Pilot, we had a total weight of 4,301 pounds with this break down:
    Weight L/F (lbs): 1244
    Weight L/R (lbs): 940
    Weight R/F (lbs): 1193
    Weight R/R (lbs): 924
    Curb weight as tested (lbs): 4301
    Weight distribution, front (%): 56.7
    For the 2017 Honda Ridgeline we showed a total weight of 4,513 pounds and a break down like this:
    Weight L/F (lbs): 1308
    Weight L/R (lbs): 995
    Weight R/F (lbs): 1304
    Weight R/R (lbs): 906
    Curb weight as tested (lbs): 4513
    Weight distribution, front (%): 57.9
    So, you're absolutely right--the Ridgeline is heavier. According to the Honda Press Site and a side by side comparison of suspensions, the two are closer to brothers than distant cousins. I'm sure it could be argued that handling is increased by more aggressive suspension tuning. You know, 'cause the Honda is supposed to compete with other mid-sized off-road trucks. I could probably jump into a long conversation with Dan Edmunds about the differences in these suspensions, but maybe your comment was more rhetorical? Tell me before I engage him though. He knows....a lot.... about suspensions. :-)
  • cjasiscjasis Member Posts: 274
    Did I miss the numbers from 2012 that were going to the basis for comparison?
  • jlaszlojlaszlo Member Posts: 60
    Besides the infuriating infotainment system that's apparently powered by a Commodore 64, love my RTL-E.
    Michael_M said:
    Hey @legacygt
    As much as I miss Dan Edmunds' suspension overviews, there's no need for more here...unless of course, he wants to do it.
    Has anyone asked why LaneWatch is only available on the RTL-T trim?
