2006 Subaru B9 Tribeca rough idle, check engine, cruise light
I have Subaru B9 Tribeca 2006. Week ago started the following problems - after starting up, engine is shaking (rough idle) for a few (20-30) seconds and then it's OK. Then I got Check Engine, Cruise and ABS lights on. Diagnose shows mistake in 1st cylinder. changed spark plug, air filter, checked all connections, cleaned injector and throttle. Lights went out and engine was working as new. but the second day car had rough idle again....
can anyone help.....
checked out everything went through all the procedures disconnect battery -- wait some time reconnect; turn the key to the on position wait a 20 seconds and start up --- put a obd2 in the vehicle scan plug -- found no connection with app --- led me to the fuse box (under drivers side dash -- 15 amp fuse for the ECU that was good --- went to the major fuse box under the hood there is 7.5 AMP FUSE FOR THE ECU --- IT WAS BLOWN REPLACED AND STARTED ENGINE UP -- THOSE FLASHING LIGHTS DISAPPEARED -- HOPES THIS HELPS YOU --- Jaker
My 2007 Tribeca B9 was fine all day and o came home and went to leave about 10min later and I started the engine and sat there for a few digging for something on my bag. All of a sudden it started idling weird and the check engine light and cruise control light are blinking and the anti skid light is solid.
