2001 Quest parking lights wont shut off..... HELP
hello all. I have a 2001 quest/villager and the parking lights will not shut off. checked all fuses and relays and was led to headlight control module. pulled the lcm out... lights still on. so.... is it smart entry control module? body control module? if this vehicle even has the bcm. i have looked all over online as to its location but too no avail until later models. any help would be appreciated. I do have the auto light option on the vehicle as the sub class is villager estate but even when i bought that brand new switch and had the other in my hand completely disconnected the parking lights were still all on. HELP please.
Answers
One possibility could be if you have a trailer hitch harness attached to the vehicle. If you do, try disconnecting it and see what happens. Otherwise the next thing to do might be to pull fuses one at a time to see which one is supplying the power that is being fed into the lamp circuit.
Just a note, the nickname for a failure like this is a "sneak circuit."
