Visitor Agreement.
These are 85,000 mile tires with supposedly excellent traction in rain and snow. This is the first time that I have bought Michelin tires, but it seems hard to go wrong from what I have heard and read about them.
Thanks for your input.
To All, please call Toyota and get a case # for Slow pickup / Non Acceleration.
Here is the # 1 800 331 4331 ext 314
$600 for the set, including lifetime alignment and hazard insurance seem like an excellent deal.
In my experience, Michelin tires always perform very well, last much longer than most other brands, and the best thing is, they require very little maintenance and care... I am a lazy guy. I dont enjoy checking tires' pressure and wear patterns, or waiting around for the shop to do their balancing, rotation, alignment... My Michelin tires are always doing fine!
Acceleration much better now.
Smooth shifting of gears.
RPM goes over 4000.
Engine starting problem is also gone.
BTW, Today I Got a call from the dealer after opening the case with Toyota. Haven't fixed appointment yet.
What is BG install kit you mentioned ?
Gear shifting got better after the service, but using 87 octane significantly improved performance. My car never use to go over 3.2K rpm and today in 3rd the gear it went upto 5000 rpm generating nice acceleration. I don't know if Camry can get better than this.
Also, I always had starting problem even when engine was hot. Sometimes I had to try 2-3 times and now car starts in the first try.
I must tell that my 99 Honda Civic was way refined than my V6 Camry. Never had a single problem. It use to half kick start in extreme winter.
I hope above helps. I am still gonna go to the dealer and keep you guys updated.
Please open a case with Toyota. I am also going to write my reviews on Edmunds.
Owner's manual suggest to put 87 octane but higher for better performance. I think my car's computer can't verify which gas is being used and that's why I had performance problems when using higher octane. I have an appointment with Dealer this weekend and then I may find out what wrong.
Could you please write how to change the air filter ?
Gautam
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/
http://money.cnn.com/2004/07/26/pf/autos/camry_recall.reut/
Thanx,
-hank2
KansasDave
cam2003=> could you please write in detail how to change Air Filter ?.
Look at picture and follow my instructions for remove the air filter
Link picture:
http://us.f2.yahoofs.com/bc/4106f921_f636/bc/My+Documents/Camary_- filter_replace.jpg?bf42vBBBk5gOTBkx
1- Loosen 2 screws
2- Disconnect 2 electrical connectors by pressing end clip and pull it out
3- Disconnect the hose: need to open the clamp and pull the hose out
4- Disconnect 2 air hoses, mark them so you know how to put them back later on
Now you can lift one end of filter box (start at screw end), slide out the old filter.
When put new filter in, pay attention the mark of side up and front of filter.
Good luck
BTW, I can't get to the page. It says "not found".
Could you please re-write the link?
Gautam
http://us.f2.yahoofs.com/bc/4106f921_f636/bc/My+Documents/Camary_- filter_replace.jpg?bfN07BBBq8IkTBkx
Sorry, I still can't open it. Returns "The page cannot be displayed".
Some reason, the yahoo briefcase would not work here.
Keith in Regina,Sask. Canada
Could you please resend the email as I haven't received yet.
It's definitely true with our 04 Solara SLE convertible also. It has a manual side-by-side alternative, however, that doesn't have the problem. But in automatic mode, it's there every time.
I suspect that the ES330 is suffering the same thing. All right, what other Toyota product has this 5-speed?
I am waiting for a response on this problem also. The dealer cannot duplicate the problem. Been back twice. They changed tranny fluid the first time around....no help. Will be taking car in for 6000 mile maint next week. Will hound the dealer for 3rd time. If they cannot fix...will try another dealer. If that does not work I will contact Toyota and really start complaining.
Thanks for the update. I am taking the 04 Camry back to the dealer for a recall on the curtain side air bags, and will get the transmission checked a 2nd time. This time I will ask that they reprogram the transmission software and check/replace the Value Body. I also wrote an email to Toyota yesterday. I will post details on what happens.
To fix the carpets and AC, it would cost me about $1,200. The estimate for the carpet is $711.00 and the estimate for the AC hose is about $400.
I still owe about 6K on the note. i bought it in 2000 with about 30k miles. Now the car has about 103k miles on it. Should i try to tell it privatel or take it to dealer and trade in for new vehicle.
Anyone encounter either of these problems ?
I consider this to be a safety issue because I can never predict just what kind of lag I'll have and how fast I'll eventually go. I'm hitting the brakes more often; plus I've been getting a strange downshift shudder when I take my foot off the gas. See my message for more detail.
Bottom line: Continue to escalate with your dealer. I have started arbitration. File your complaint and the company will have to address the issue. Good luck.
Check for sparks at the plugs.
Check to make sure the fuel pump works.
Spray into the fuel injector's inlet with 2 cans of fuel injector/ carburetor cleaner as you crank the engine to clean out plugged injectors...
Leon
I get a bit of a warning a few minutes before it dies with some stuttering or lurching (and the rpms go down when that happens). When it dies, it just stops entirely. No nothing. No sound, no engine...nothing. But, the dash lights come on and the radio, if on, stays on. He's checked the alternator and the battery and the spark plugs and says they're all fine. He also was unable to find any computer malfunction codes.
I don't drive my car much (it's an 86 with just 133,000 miles on it!)...just short in-city trips a few times a week.
I found one message on here that sounded like a similar problem (wong?) but there wasn't really a response to it. So, I thought I'd sign on and try again.
I'm at my wits end...I still have to drive it occasionally and I'm taking my life it my hands when I do. It's very scary when it just stops.
Thanks for any help!
A week ago I filed a complaint with Toyota on an intermittent jerky shift from 1st to 2nd gear ... feels like I am riding over a washerboard for 1-2 seconds. After several days, Toyota told me that no one else has filed a similar complaint on a 4-speed transmission (although they acknowledge a problem with the 5-speed transmission). I would like to hear from anyone who has a jerky shifting problem with a 2004 Camry with a 4-speed automatic transmission. I am particularly interested in whether you filed a complaint with Toyota, whether Toyota fixed the problem, and how they fixed the problem. If you have a Technical Service Bulletin number on this problem, please share. Thanx
