By the way, I fixed a weird creak (I thought my dash was haunted) that was coming out of the dash by putting in the aftermarket MP3 player I had in my last car. It was either that or an exorcism. I wasn't going to put it in at first because I didn't want to cause any squeaks or rattles. Guess how that worked out! So anyway, stock radio out, new (old) radio in, no squeaks or creepy creaks, and I have another storage area in the dash as well. I'm going to use it to hold my earplugs for those times when I have the radio off.
One nice thing about the Camry-you can install an aftermarket stereo. With the Accord or Mazda 6 it is more difficult or impossible. With the Accord you put it in the storage area below the dash and keep the stock radio installed too. Weird. With the 6 I think you have to use a welding torch.
tell them what you told us, keep going to them until it's solved.
Steve
Also, how do I open up the console?
Steve
If it is the seals is it worth fixing? If not now, at what point?
Do you know if this is going to give me trouble passing the NY State emission inspection?
still looking for a mechanic who might know what it is.
i'll keep you posted.
good luck.
My driving hasn't changed, but use of air conditioning has been reduced, a little.
I thought I read a rumor that it takes about 5000 for the fuel injection computer to adapt to your driving style... but I can find anything definitive.
HTH,
- hank2
Steve
It basically depends on whether it bothers you enough to get it repaired. As I mentioned, mine has been burning oil at startup for almost 5 years and it hasn't obviously worsened. I don't drive the car hard so I haven't noticed a drop in performance. Checking the oil regularly is a must, for me because I have a light rear seal leak, for you because your engine may be burning more oil than mine. It's a fairly expensive repair--pretty labor intensive, so this may be another factor. I intend on doing a pretty thorough restoration on my Camry in the near future, so I'll get mine fixed at that time. Again, it's not a do-or-die issue, just keep your eye on the oil level and set aside at least $500, maybe twice that, if you really want to fix it.
Steve
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We apologize for your dissatisfaction with the driving response of the 2004 Camry.
The poor response you described typically surfaces either when the accelerator is depressed fully to the floor or when depressed an aggressive manner. The newer version of the Camry has transitioned from a manual throttle linkage to an electronic throttle control system. The electronic throttle control monitors the everyday driving habits of the operator and then tailors itself to make the most efficient gearshifts. On rare occasions when the operator fully depresses the pedal or depresses the pedal in an aggressive manner, the system may experience a delay in determining how to make the optimal gearshift.
At this time Toyota has no plans to make changes to the shift characteristics of the transmission. To minimize this condition, we recommend trying a firm yet gradual application of the accelerator.
Your feedback is appreciated; it is through communications such as yours that we become aware of our customers' expectations and reactions. It also provides us with valuable insight when planning and developing future products and services to increase our customers' satisfaction.
Your email has been documented at our National Headquarters. If we can be of further assistance, please feel free to contact us.
Toyota Customer Experience
How many miles do you have?
Oh yeah, this is our first Toyota and quality is far above average....best car we ever owned.
It shut the light off...for about 10 minutes. Then also "out of nowhere every warning light came on and the engine stopped running." No signs, symptoms or previous notice of warning lights. That then and there was the only time the car left me stranded. When the car was towed home, I wanted to crank it, and the starter kept enlessly spinning.
The mechanic said the issues was an extremely worn out timing belt whose gear teeth were so missing that it just skipped the timing gears and threw the whole timing off. Had to replace belt, stripped gears(camshaft), oil pump, oil pump gear and lots of seals.
So to sum up, check you timing gear often and replace every 50,000 miles.
I've gone to the same repair shop for more than 15 years ... and for simple (eyeball) diagnostics, they usually do for free. For example, I've asked about the brakes a number of times, and they would pop the wheels and look, and tell me to come back in 10K miles. He could have changed them and charged me. So, it doesn't hurt to call up a service manager and ask.
re: 1989 Wiper Motor - Same as above, ask a Toyota service manager. But I'd bet it is like the heater switch... and a fuse is blown. Unfortunately, that is a $34 fuse, if you can find it. Again, my service manager was more than happy to give me suggestions ... with no gurantees, unless he did the work.
HTH,
-hank2
