Visitor Agreement.
Is it worth putting up a stink at the garage? I want to get what I paid for!!!! I might not get 100K outta a rebuilt radiator. Either way my baby is better so I'm not to pissed.
Toyoman1
Appreciate if anyone knows why this happens...
Ken
Has anyone ever been covered undered this Emissions Warranty Enhancement for repairs? Knowing that you have to get the problem checked out at a Toyota Dealer ($100.00) before they tell you whether it is covered under the warranty.
I just had the tranmission rebuilt $1400.00 and now this engine light shows up. I'm getting ready to put it up for sale by owner. It has 119K miles and one owner me! So I need to hurry up and get it ready for selling so I can buy my new car. I've had it with this camry.
As I drove it for a few days I began to realize that the feel of the drive is totally different from the '00 model. Although both are 4-cyl., the new one is not smooth in its gear transition and is somewhat noisy in achieving 35 mph. The gas pedal has a
"trigger" touch that kind of pushes unsmoothly.
I had a different dealer check it to make sure it wasn't a single-car issue, and was told it drove as it was supposed to. I'm really not enjoying in-city driving.
Anyone out there know what I'm talking about?
Did Toyota alter the transmission somewhere between '00 and '05?
Hope this helps.
Ken
Thank you. You're the first to acknowledge and explain the difference.
Active18
Ken
Emissions Warranty
Here is an Excerpt:
"The enhancement coverage is on the Evaporative System and is extended to the components specified below for a period of 14 yrs or 150,000 miles from the vehicles in service date, whichever occurs first.
-Evap storage canister
-Evap system pressure sensor
-Fuel cap
-Fuel tank
-Fuel tank filter neck
-Purge valve
-Tank vapor vent line
-Three-way valve
-Any ohter part or component, including any maintenance parts, between the fuel tank and teh intake manifold (but not including the intake manifold) designed to contain or conduct fuel vapor from the fuel system"
I took my car to the auto store to get my car tested, and its showing an error code of P0440. What would you suggest that is wrong with it? And how would I go about fixing the problem?
Please any and all comments welcome!
I bought a 2005 Camry LE and just got my 5k service done at the
dealership. I was finding the brakes a little weak, hence I told the
dealership to check the brakes. They came back with a quote of $1000
saying that the rear brake drums, cylinders everything needs to be
replaced. The Brake oil is burnt and has to be drained out using a
special machine. They claim that this happens if you have driven with
the Emergency brakes ON.
I had always thought that the brakes were soft but thought that this
might be because different cars have different braking powers. I spoke
to some people and told me that if you drive with your emergency brake
on then you would see the friction/drag in a mile or so. I dont think
this car has been driven with the Emergency brake ON.
This car is 3 months old and has 5K on it. The dealership tells me
that we cannot claim warranty because it will get rejected and I
cannot use insurance because insurance doesent cover wear and tear. I
think the brakes have been degrading and now when i notice a
substantial problem. i dont want to spend $1000 on a brand new car.
Any suggestions ?
Hope this helps.
Ken
My guess is that the parking brake was on lightly, enough that the rear brake shoes were continuously applied to the brake drums while you were driving those 5000 miles. This would overheat the rear brakes and cause the damage you described. If the rear brakes were on lightly, you wouldn't necessarily be able to tell by the way the car drove, but the warning light in the instrument panel should have been on.
Has anyone been experiencing BAD engine tapping (like valves) when the vehicle is in gear? My 2005 Camry sounds like my 95 Beretta, which has bad valves. The dealership changed the main drive belt, but that did nothing. The area rep. for Toyota reviewed my file and stated that the problem is a caricteristic of the 2005 4 cyl. Camry, and this was determined without him/her putting eyes or ears to my vehicle. Toyota said they stand behind the area reps. decision, who just started working for Toyota, and that they will not make anymore attempts to repair this problem, and that I need to arbitrate my case. This vehicle has 1500 miles on it.
Thanks in advance for your help!
NIKI1
Gerryd
Bernie
I think his solution is to have someone pull the fuel door level (under your seat) and have another person use a screwdriver to pop the fuel door.
I believe he is still looking for a better solution, you can search for it (I think he posted it only a week ago)
I can also tell you from owning both a 2004 Camry 4-cylinder that I just gave to my son and new 2005 Camry 4-cylinder that the engines are as smooth as silk, as was the 1997 Camry 4-cylinder (with the earlier design) that I had previously.
I think it's fruitless to keep asking on this board if someone else has the problem, because it's probably very rare (and nobody has come forward yet).
Something is seriously awry here -- either you're leaving out some information or the dealer AND area rep are totally incompetent. You are going to have to get aggressive with Toyota.
What would happen if you went to another Toyota dealer, of course not mentioning that you've already had the problem looked at by your selling dealer? And you really don't know it's the valves, just because it sounds like your Beretta, so I wouldn't say anything other than the engine is making a terrible noise. Make sure they hear the engine while it's running.
Alternatively (or in addition), you could pay a trusted, reliable independent shop to give you a diagnosis in writing that you could use as evidence.
If you have to arbitrate in the end, go ahead and do so, but if you don't get satisfaction, I'd seriously consider hiring an attorney that specializes in lemon law cases.
This will probably be my last post to you on this, so good luck! Let us know, however, how it turns out.
Also, if you bought your car from other than a private party, couldn't you ask if the seller will do it for free?
BTW, I'm pretty insensitive to seat differences, but my wife is the opposite. I'm fine with my current and former Camrys, but my wife didn't like the nonadjustable (except seat back angle) passenger seat on our '04 LE, which I just gave to my son. The fully adjustable (except lumbar) power passenger seat on our new '05 XLE suits her much better.
1. It pulls to left since day one. Dealer has repaired 5 times without results.
2. Tires wears too fast. At only 15,000 miles, many treads were already gone. I have rotated tires serveral times.
3. It surges at around 30mph. Drive-by-wire is not so good.
4. Windshield bottom rattles. Dealer replaced the cowel with only temporary results. After several weeks, rattle came back again. It feels something is loose inside. I was ambarrased letting friends sit in my car because of the rattle.
5. Rattles from door panel areas.
6. I heard rattle/vibration noise from engine or under vehicle every time I started the car and hit on gas to drive it. Dealer said it is the intake manifold. After they replaced it, the rattle is still. Yet, dealer refused to admit it.
7. Starting from around 8,000 miles also, I smelt strong rotten egg smell. Dealer said they have to replace the converter. After repalced it, they said they had to re-program the ECM. But after they have done all of these, the car started to feel heavy - acceleration is hard, steering is hard, and it is hard to brake. And the car started to get into mystery: sometimes it is normal; sometimes it is really hard to drive(hard acceleration, steering, and brake). Engine is noiser than before.
It seems like every time the car had a problem, dealer's fix either didn't fix it or introduced new problems.
So, I sold the Camry. I don't want to spend any more time and energy on its problems. I recently bought a new 05 Chrysler T&C at only $15,500 (include all the charges, tax, fees, etc.) I am really happen with it.
I really disappointed with Camry and Toyota!
I don't think the problem is due to throttle-by-wire. And I certainly wouldn't want to go back to the old days of throttle cables or linkages sticking or binding.
I guess GM had so much trouble with throttle linkages in the past that they still have the linkage as an item that must be checked at regular intervals, according to the Chevy Cobalt maintenance schedule that I saw.
I appreciate any intelligent response.
Good Luck!
I have the same problem with my 2001 Camry. would love to hear what happened with yours . Can I e-mail you directly or call you? I have 103,000 miles on it, and the warentee expired at 100,000. Car cannot be driven, and am considering another engine, but do not want the same thing to happen at 100,000 miles. Any help is greatly appreciated, thanks, doug
Douglasm, if the car can't be driven, the problem must be more serious than what the others are reporting. Have you had the car looked at?
One other observation: it seems the dealers are increasingly lazy or incompetent. This makes it all the more important to search not only for the best deal when buying your car, but also to check for the best reputation for service, especially if you're not going to be doing your own maintenance.
Hope this helps.
Ken
Ken
I'm sure you're going to get many more wonderful miles out of your Camry as I had mine before trading it in recently on a Tundra.
Toyota Ken
By the way, I'd probably still be on my first Camry, a 1997, except for two things: I wanted side curtain airbags after the impressive IIHS side test crash test results for the 2004 Camry so equipped. Thus, I replaced the 1997 at 111K miles with a 2004. Then my son got accepted into grad school in Southern California and will need a car. After searching long and hard for a suitable, affordable used car with head protection side airbags (and good crash test results), I ended up giving him our 2004 and purchasing a new 2005 Camry. Rather expensive, yes, but children are priceless!
Toyota Ken
Quick question on your T&C deal. Was it a new one? Was there a trade involved. That price seems way cheap if I compare it to the price Edmunds show 'em going for. Can you elaborate a bit, if they are selling that cheap I may be interested in one.
