One thing I've learned with the Purolator vs. the Toyota OEM filter is that the Purolator has more rounded off flutes, which makes it harder for the cap-style oil filter wrench to get a good grip for removal, if the filter is on a little too tight. (It's hard to tighten the filter by hand because of clearance problems, so it's tempting to use a wrench, which I no longer advise -- see below.)
The OEM filter has better defined flutes which ensure a better grip. I learned the hard way, so I'm only going with OEM filter from now on! They really don't cost that much more. And I'm only going to tighten them by hand.
If you do hand tighten, be sure to check for leaks after you've run the engine for a short time after installation.
I just bought a Camry SE 5spd AT in May. My cars is around 3k now. My car has some strange problems that I am not sure if they are suppose to have in a new car. My camry doesn't accelerate fast. When driving on freeway, when I slow down from 70 mph, the car would never speed up again, it would stuck on 50 mphs no matter how hard I press the pedal. When going on 20-40, the car jerks. When going up a little elevated hills, just a very slight elevation, the car would stuck on 40 and never speed up again, no matter how hard I press on the pedal, even a corolla able to pull through w/o any dramatic slowering. The brake also feel very lose, I always over shot, the car slide unless I floor the brake pedal. I am not sure these problems are suppose to exist or there's a problem w/ my car. Just wondering does anyone experiencing this kind of problems on a new Camry?
I used to change my own oil and use FRAM until I went to a toyota dealer for an OEM (with discount coupon). Man, you can tell from the cut out displace they show, the OEM one is way better than the cheap-o-paper FRAM.
For a dollar more, go with the filter from your toyota dealer.
If you still wonder, go buy both and cut them open to see the different yourself.
You didn't say which engine you have, the four or the V6.
I have had both an '04 LE 4 and an '05 XLE 4, the former with the 4-speed auto and the latter with the 5-speed auto, and have never experienced any problems like yours.
I just read article recommending red coolant, toyota brand.
What should I do? Change back with expensive red coolant, toyota brand.
Any suggestions?
Or you could ask the first dealer to pull a 2003 Camry from their used car lot, and I bet it won't have the problem. It'd be interesting to see what they say.
For 2004-05 Camrys that are factory filled with this coolant, the first recommended change is at 5 years or 105,000 miles.
For an older Camry, it probably wouldn't be a good idea to keep it in that long, but certainly more than 30K miles is okay.
I'm not sure in what year Toyota switched to the Long Life coolant -- maybe with the Camry redesign of 2002?
Can you help with any ideas???
1. Sunroof started making noises (needed lube and adjustment).
2. Passenger door developed a bad rattle.
3. Drivers seat began sounding like an old sqeeky couch(Is there a weight limit?!)
4. Shifter housing needed replacement...very loose while in gear. I should add, that it was like that from the beginning and dealer denied something was wrong the first time. I brought it in to fix the rattles and they said it needed new housing, after I drove it for 3 months.
5. The chrome exterior window trim developed tiny rust spots which had to be buffed out.
Despite those quirks, the engine is great and so is the mileage...easy to go 450 miles before light comes on in mixed driving. However, I am somewhat disappointed in Toyota's interior quality as you might expect after the rattles. This car was built in Japan; June of 04 I believe.
I was wondering if I could get some assistance on trying to figure out what is wrong with my car. The a/c when I turn it on gets really cold but after about 20 minutes or less. The cold air just stops and returns to the normal tempature (outside). My camry is a 1995, le. I understand that the owner manual says that if the a/c turns off by itself then it is a fail/safe which means something is wrong with the compressor or drive belt. Obviously I'm on the edge of having no idea what I'm talking about, so please if you know what may be wrong let me know. Thanks!!!
Hope this helps.
Ken
If your bumper was never damaged, it's still possible that the factory paint on the plastic cover could change color faster than the paint on the sheet metal. But I would expect the front bumper cover to exhibit the same problem. I'm pretty sure (but not absolutely certain) that the body and bumper covers are painted together on the assembly line.
With a 4-year-old car, I highly doubt Toyota will pick up the tab for repainting the covers. Also note that it's tough to get new paint to stick properly on a cover without extra care, and I'd rather have factory fading paint than dealer or body shop peeling paint!
My 2004 had a few minor rattles that largely went away on their own, and my 2005 has been very quiet. Regarding item no. 3, a co-worker weighs about 280 pounds, and his 2004 Camry developed a squeaky driver's seat, plus the outer part of the seat cushion started to wrinkle up (not just the fabric, but the foam inside). Both problems I think were exacerbated by his weight.
Regarding item no. 5, I'm puzzled because I'm pretty sure the "chrome" exterior trim is just chrome-plated plastic. Nobody uses metal anymore on such trim, the only exception being bumpers on pickup trucks. My Nissan Frontier, for example, has a chrome-plated all-plastic grille and headlamp bezels.
Ken
We've had to replace the front strut, the brakes system, and recently (2 weeks ago) spent $2000 on the car when blue smoke started coming out of the exhaust and oil was getting into the engine. The starter has also been replaced twice (part of that recent $2000). Now, I hear a noise from the rear strut that sounds all too familiar from when the front one had to be replaced - and all we do is drive around town! I keep hoping this car will be as reliable as it should be, should I give up?
We got an offer of $4500 from one of those used-car memega stores.... should I get rid of it before something else major happens? On the other hand - have I replaced all the problem areas and now it should be good as new? The dealer thinks it is in "good shape now" - what does that mean??
Thanks for the help!
What's the trick to get at the bulb?
Thanks. john 86
1) Pulling into a parking space and having to make a sharp turn into the spot.
2) Backing out of my garage, I pull out and back the car in either direction. When I turn the wheel the other way (i.e. It's cranked one way and I have to turn the wheel so it's straight), I hear it making the noise as I turn the wheel.
3) If I am parked somewhere and just turn the wheel back and forth repeatedly, it will make the noise some.
Since the car is out of warranty, I was wondering if people could give suggestions of thinks I can look at (vs. spending the money to bring it to the shop). Thanks!
Hope this helps.
Ken
Based on what I got for my '97 a year and a half ago, I'd say the $4500 offer is too low, as yours has far less miles.
I had the blue smoke problem also -- twice. The first time it was fixed under warranty, and the second time I just let it go -- and disclosed the problem to the buyer on eBay.
It's not really that serious -- the valve stem seals harden up and let accumulated oil from the top of the engine leak down into the cylinders while the car is parked overnight. Once you start the car, the oil gets burned and the blue smoke comes out. Once the car is running, it won' t emit blue smoke again, until the next morning (at least that's the way mine was).
In my opinion, once you start to see a problem in your car, everything starts falling apart.
Yes, you can hope you already did all the major fixes but reality is 'it's just the begining'.
However, since your 98 only have 70,000 miles, $4500 is kind of low. Maybe you can sell it yourself, should be around $5800-6500?
Or drive it for another 3k miles and see how it goes.
Zetnet
Anyway, had car in and asked for a tire rotation. They called and said the rear brakes were wearing fine but were out of adjustment and if left unattended would cause the front to wear quicker. $36 to readjust. I said fine but then started to wonder...I never heard of an adjustment and noticed no problems while driving. On the other hand the car has 34K miles and the opriginal set of brakes.
Anyone ever have this or can explain what they might be doing....
But for $36, I wouldn't sweat it.
ANY ONE KNOW ABOUT THE LEMON LAW FOR GA
thank ya
I just bought the car 10 days ago, so depressed by this.
Thanks for any inputs.
