Although the engine redlines at 6500, the tranny typically won't let you rev past 5500 before it shifts. Once I had the problem, I tried to duplicate it a few times and sure enough every time I rev it up it happens.
It hits about 5000 Rpms, then starts to shift to the next gear, then hesitates and clicks back into the same gear unless I let off the gas pedal a little. It doesn't seem to matter what gear it is shifting into either.
Anyone else have any clues?
Replaced the rotors recently?
The steering column doesn't grind on either one, but they both squeak a little.
Sounds like a kid on a rubber inner tube. It's wierd. No idea what it is either...
It only seems to happen when I turn it quickly though.
a search of 210delray revealed he blue smoke at 57 and 111k, before listing his 97 on e-bay. a bit early for stemseals, to say the least.
I remain suspicious about lubrication/temperature issues for any of these problems, but if anyone has a verified notice on a stemseal recall....chime in.
better yet, have the appropriate testing done in conjunction with a compression check - and post the results here. If delray (and alcan) are right; it will only cost you 2 grand instead of 5.
I did eventually use 15 ft/lb as the torque. The cars runs with no problem.
The old plugs from cylinder 2, 3, and 4 look completely normal, just with some worn and ash deposite. However, the thread and electrodes of the old plug from cylinder one are soaked with oil. And there is sign of burning on the portion just above the flat seat.
I installed the new plugs. And drove for about 10 days. Took out the plug from cylinder one. Again I am seeing oil on the thread and electrodes.
Anybody can shed some light on what the problem might be? How to fix it or how do I ask a shop to fix it?
However, the Five Hundred has not yet been tested in the side impact test.
It is a tough test -- it simulates a large SUV or pickup hitting the side of the test vehicle, in the passenger compartment area. In cars without side airbags, the driver's head usually makes direct contact with the intruding barrier face, equivalent to hitting your head on the impacting SUV or pickup. The test speed, however, is a relatively low 31 mph.
Side airbags serve as a cushion that intervenes between the intruding barrier and the dummy's head -- and this makes an important difference. Also, the car's structure (doors, pillars, and door sills) must be strong enough to resist significant intrusion.
In the IIHS test, the rear dummy does usually fare better, because the test is set up in a way that maximizes intrusion at the driver's seating position.
Yes, by all means side airbags that protect the head should be standard, and NHTSA's planned upgrade of the side impact standard will necessitate that all vehicles have these airbags in the future.
The 2004-05 Camry with side airbags scored a Good rating, and since the 2006 model will be unchanged, its test results (with side airbags) will also be Good.
The blue smoke on startup began occurring again at 102K miles. I didn't bother with a repair this time. I sold it on eBay with a disclosure in early 2004 at 111K miles. It was sold not because of the smoking, but because I wanted to get side airbags on a 2004 model.
I changed the oil and filter at 5000 miles or less throughout the life of the car. I also changed the coolant at 30K miles and 60K miles. At 60K miles, I switched to Dex-Cool long life coolant.
I checked (and continue to do so for my current vehicles) the oil, coolant, and other fluid levels weekly, more often on long trips. The '97 Camry never overheated.
I have not heard of a recall for the valve stem seals on the Camry 4-cylinder.
Now if the vibration occurs most noticeably while braking, then I'd guess the front brake rotors are warped.
Is your gas mileage remaining consistent also?
Regards
I just picked up my new camry SE 4 cylinder and I noticed that the car vibrates a bit violently in park (idling) and when I come to a stop at red light.
If I put the gear in neutral it becomes smooth and I feel no vibration.
I did not notice this problem in a test drive and I assume that It's not normal for a brand new camry to vibrate like mine does.
Did anyon else experience the same problem?
Is this normal or am I being too anxious?
BTW, I haven't had a chance to take it back to the dealer yet..
Okay, now I'm mad. I got a 2004 accord and they say use honda trans fluid or you'll ruin the trans.There's other things we don't like about the honda so I got a new 2005 camry LE. Love it but just read the manual and it states that I have to use toyota trans fluid like the honda or else suffer the consequences. Okay, so I go and buy 3 qts from toyota every 30K or so (I change mine frequent to avoid issues). But it used to be that you could use dexron III for trans fluid. did so on my 1994's and my mom's 1998 model camry. That bites. So much easier to go to auto zone and the like and get a name brand trans fluid. Just like oil. they say use toyota oil (give me a break). I use castrol in my cars and it's better than the toyota stuff any day. As for power steering fluid, it's dexron III (go figure).
Has anyone used dexron III fluid instead of the toyota trans fluid???? thanks
BTW, you don't have to change the fluid every 30K miles anymore according to Toyota. In fact, if your car doesn't meet the "special operating conditons" (severe service), you don't have to change the fluid at all. However, a good compromise would be to change it every 50-60K miles.
You're not required, OTOH, to use Toyota-branded oil. Any quality 5W-30 oil with an API rating of SL will suffice.
Nothing to get mad about, IMHO.
I don't know what the problem is, but since your car is new and under warranty, you should take it back to the dealer as soon as possible. Demonstrate the problem while you drive and a service tech rides along.
It is a picture of a car with what appears to be the brake lights on.
I did not get an owners manual with my used car. I have one on order.
Anybody know what the warning is for? :confuse:
The only way manufacturers can require you to use their oil and their filters is if they supply them; otherwise there's a law that was passed requiring them to honor warranties even if other brands were used.
I never run into any dealers that use TOYOTA's engine oil at all. BUT they do sell it in their part and service department
Another thing is keep adding new ATF into old ATF just doesn't sound effective. Maybe instead of spending the money on ATF, just have the tranny flush once and you can sure to see the "PINK" in your ATF again.
In this area I hear problems occurring after flushes. I'll stick with drain and filter changes occasionally for my own tranmission. I drive the car up on blocks and crawl under and less than an hour later, I'm done. I've seen the crud in the bottom of the pan to analyze any major problems throwing off debris; that doesn't happen with a flush. The flush is considered by _some_ as a transfer device; it transfers money from your pocket to the repairman's pocket.
Occurs with and without the a/c and with and without the blower for the heat/a/c blowing.
Any thoughts?
Bill
Any one of these 4 bulbs could be malfunctioning, so replace both pairs, or at the very least, replace the outer pair first and see if the warning lamp goes off.
I think this system compares the electrical resistance in each pair of filaments, so if there's a significant difference, then the warning lamp illuminates. (It does not necessarily indicate a bulb has burned out.) This is why the bulbs should be replaced in pairs, as a new filament will have a different electrical resistance compared to an old bulb's filament.
This warning lamp is separate from the "BRAKE" warning lamp, which warns of low brake fluid level in the system, and the possible need to replace the front brake pads. (All cars are required to have this.)
If you're concerned about the fluid, then I'd say just to drain and refill at frequent intervals; even though only about half of the fluid will be replenished at any one time, over time, all of the fluid will be exchanged.
BTW, imidazol, I hope you're not literally driving your car up on concrete (cinder) blocks. These can fail without warning. Get a decent set of ramps instead for your safety!
The theory about all the fluid will be exchanged over time just kinda of hard (for me) to believe.
I know some people in this board against Transmission Flush because of certain concern and cost, I can understand that. I feel that adding and mixing old fluid, or taking out the bottom cover frequently (with new gasket) sounds even less effective and require more work. (get under the car, collect the old fluid and find a place to recycle it...)
I do support your safety concern about using a good set of ramps when working under any car (bad experience when working in my old car)
I purchase my '05 Camry LE w/15" wheels about 2 months ago. Last weekend, I took my family on a long drive and since I was not familar with the area so I took my Garmin GPS unit with me. It was during this drive that I noticed the speedometer was off about 4 to 5 miles per hour (at around 70.5 mph on GPS, speedometer was reading 75). In city it was off about 3 to 4 miles per hour and at 90 mph it was off by more than 5 mph.
I went to the dealership yesterday and they told me that the speedometer is set at the factory for each specific car and there is nothing they can do about it... I'm really concern because this means my odometer is not accurate.
Did anyone else w/15 tires experience the same problem?
How about others with 16" tires?
Technically, Toyota doesn't even call for changing the ATF at all if the car isn't used in severe service. So if you change the fluid, say at 15K mile or 30K mile intevals, it's true that you'll be mixing old and new fluid, but over time, the amount of original fluid in the system gets smaller and smaller. And you'll still be far ahead of not changing the fluid at all.
I have no experience with GPS units, but you might want to try a using a stopwatch and compare your speedometer against highway mile markers. Keep your speed constant, and do it for at least 10 miles. 60 mph is a good speed to use, since that is equivalent to 1 mile per minute.
BTW, speedometer error and odometer error aren't necessarily the same. So check your odometer against the mileposts also. You don't need to maintain a constant speed for odometer checking, so you can do it over a longer number of miles for a more accurate check.
I find it hard to believe the dealer can't do anything. It used to be possible to change the gearing for the speedometer. 15 vs. 16-inch wheels shouldn't have been the problem, but it is true if you put 16-in wheels on now, the speedometer would be more accurate. (Larger tire/wheels = fewer tire revolutions per mile, meaning the speedometer will register fewer mph.)
BTW, imidazole is your name. you must be a chemist.
The reason why I ask is in my 1994 camrys, I had to drop the trans fluid, filter and there is a separate differential (near the trans itself) that I had to drop a drain plug and refill it with a fluid pump as the fill hole was on the side of the trans/differential.
Note, the manual doesn't list a differential fluid/maint schedule so I'm thinking its' all in the trans like the new hondas.
Thanks for the replys.
I reported this on my Purchase Survey to Toyota. I am waiting for reply.
Otherwise I am very satisfied with the car. It rides and handles like a dream. The car is so refined . I am disappointed that the speedometer readings are not accurate.
Toyota looks like the worst offendor on the list. Some manufacturers actually are very conservative and underreport the HP.
Toyota, Honda inflated claims of engine muscle; new tests force automakers to come clean with buyers
Why?
1. Detroit is the home of the "Big Three".
2. Detroit News and Detroit Free Press are recognized as consistently biased toward the "Big Three."
3. The "Big Three" are all in trouble--big time--with plummeting sales, financial difficulties, and serious market share declines.
4. Toyota especially, plus Honda and a couple of other Asian automakers are consistently outperforming the "Big Three" in sales increases, market share increases, quality, reliability, resale value, new technology.
5. What kind of news would anyone expect from a newspaper in the home court of the "Big Three?"
6. The "old" SAE testing procedures were used by all automakers, and now the "new" testing procedures deliver "different" results.
So what does anyone expect "new" procedures to deliver--- the same results as the "old" ones?
7. Where did demand for new testing procedures come from--SAE??
Don't forget that the majority of members are employed by the "Big Three."
So I suggest that your use of the words "Unscrupulous", or "Worst Offender" is unfairly applied to just one automaker.
They all used the same "old" system to determine HP ratings, and they now all use the "new" HP ratings.
Every one of them is affected to a greater or lesser degree.
The Automotive Industry is a bitterly contested battleground. It's "Kill" or "Be Killed" out there, and Public Relations play a huge role in the combat tactics used by all automakers.
I have a four-cylinder '05 Camry. So under the new procedure, the horsepower is down from 160 to 154. I'm not going to lose any sleep over it!
Actually, the Detroit Free Press in my view is rather even-handed when it comes to reporting on domestic vs. import makes. The Detroit News is more partisan, but even it ran an aggressive series on the weak roof strength of domestic vehicles, particularly the last-generation Ford Explorer.
