2014 Chevrolet Silverado 1500 Z71 LT Crew Long-Term Road Test
edited March 2016 in Chevrolet
Loading our 2014 Chevrolet Silverado 1500 at night is a snap because of its powerful bed light.
  • milt721milt721 Member Posts: 83
    There is also available under rail bed lighting which your truck seems to not have. Only $60 MSRP.
  • bwelch88bwelch88 Member Posts: 1
    My only complaint with the bed light on my 2015 (a 1500 Double Cab LT Z71 4x4) is that they cannot be engaged while the vehicle is in drive. Neutral? Fine. Reverse? Good to go. Park? Gotcha. But D or M? Not a chance. The switch 'enables' the light, but it only shines when in something besides forward. Not good if you want to keep an eye on a potentially unstable load at night (or flash it a couple of times at a tailgater). Not that I would ever do that ;)
  • tfcpapatfcpapa Member Posts: 1
    my 2015 duramax bed lamps will not come on in reverse! A real [non-permissible content removed] when you are trying to hook up a goooseneck trailer! Can I bypass this?
