Visitor Agreement.
I had the same problem on my van and I had the starter rebuild ($120.00)
If it's a 4-cylinder, the labor cost for just replacing the spark plugs should be minimal.
It seems to me if you can show a judge you maintained the car by the book, and the engine failed at such a low mileage, you could win in court, if it came to that.
I suppose you could have taken the Camry to an independent shop first, but that would have cost extra money. On the other hand, you hopefully would have been able to obtain an unbiased diagnosis. Still, only Toyota can repair the problem for free, if they so choose.
*By the way, folks, "Lemon Law" cases ain't what they're commonly presumed to be by the public. The terms aren't a simple one-for-one trade to a brand new vehicle like the consumer rights lobbiests like to promote. The amount of time the "lemon" was in service will be factored in determining the value of the "lemon" against the MSRP price of the replacement car. (and by using the MSRP of the new car, that also assures the dealer and manufacturer will gain some further monetary advantage) In other words, if you win a "lemon law" resolution, you're essentially just trading in your lemon for a new car minus the depreciation for service attained. In a car eight years old at the time an engine tanks, the achieved use depreciation would pretty much negate most of the old car's value, anyway. My son-in-law fought Ford over a buggy Focus for over two years and finally "won". When it was all over, he'd have been better off just trading the original Focus as soon as it started acting up - it had enough extra resale value at that point to have been worth more as a straight trade against a new car that he could've negotiated the final price on than his final out-of-pocket expense eventually resulted in. Of course the dufus won an intangible moral victory against $6,000+ out-of-pocket personal expense. Its ultimate value? "priceless"!
Of course you can try bubble gum...
since the stalling started after the "tune-up", maybe there is a hose or something else which was left unattached (sensor wires?) or got crimped. seems like something might not have been put back together properly.
Bingo! It mystifies me why automanufacturers feel it's necessary to hide the engine under a piece of plastic with cutesy metalized bright logos. I always felt the intricate castings of the art and craft of well-wrought mechanical engineering were works of art unto themselves and worthy of being displayed and admired when the hood is raised. So far I have not seen these abominations to good taste mounted on Ferrari engines. The plastic cover for my Sonata V-6 resides in a place of dishonor along a wall of the garage - in case the car's next owner disagrees. (or in case I can unload the stupid thing for profit on eBay... As Tim Allen might've quipped on Home Improvement, "Real men don't need sissy plastic engine covers! Aurgh, aurgh, aurgh!")
I always figure I'm helping the air flow for extra cooling by removing those silly covers they spent $1.50 on instead of some other feature they could have kept and left off to save a few pennies here/there.
Wow -- 4000th post!
I recommend eBay highly for selling, especially if you have a car without problems. (I wouldn't buy however, unless I could inspect the car ahead of time.)
So... I am getting really fed up with this car. I went to get out of it after getting to the college today and bam! the door handle breaks off right in my hand. The plastic didnt break, the handle just popped out of the assembly. So now my options are leave the window down and DUKES OF HAZZARD it to get in and out, or replace it. How hard is it to replace and if I take my door apart am I going to be able to put it back together, I dont wanna look ghetto. If anyone knows or can help, PLEASE PLEASE DO! Not so happy motoring anymore
Toyoman1
If you want to tackle the repair yourself, I believe you can if you have a basic mechanical ability. The thing you need is a diagram of where the clips are that hold the door into place. The easiest place to get one of these is Crutchfield (the stereo catalog place). I had a '92 Camry and needed to replace a power window switch when it was 8 years old and they sold a how to install booklet that showed how to remove all of the door panels (to replace speakers) as well as how to remove the stereo head unit. You may need to buy a inexpensive tool to remove the clips as well. It worked well for me, no broken items. I even decided to replace the stereo after this.
But anyway, once you have the door apart, you will be able to see what failed and replace it without too much trouble. Either with new or junkyard parts. Don't get too fed up with your car, ten years can put alot of wear on a door handle mechanism. It could be something worse breaking. Your '95 is one of the best car models ever built, but no car is perfect, especially after ten years.
Good luck,
Jayme
There is a lot of Cranking Noise when i accelerate the vehicle and i took it to the mechanic nearby, he has drained the Engine oil and noticed the metal deposits in the oil. later he thought the Connecting rod bearing might be broken and he removed the oil pan under the engine cylinders. We noticed lots of Brass metal pieces which are in a few millimmetres size. Then he said i need to replace the Engine altogether.
Can someone advise me please if they had a similar problem and let me know the possible solution if u know of one.
My car has 83K miles on it.
Thanks in advance
Raj
Why its happening?
Pls share your experience. How much it may cost to fix it? I just did my 60K major services. Since its intermittent, they could not reproduce the problem there. But its happening on and off.
Why its happening?
I own a 2002 Cmry 5 speed which I purchased new. The clutch just failed at 72K miles. I have owned several std transmission cars and never had a clutch fial before 100K miles. I noticed and reported that the clutch peddle felt stiff. I believe that there is something wrong with the linkage since the car was new and it manifested itself into a premature clutch failure.
To make matters worse the 2002 Camry requires 11 hours of labor to change the clutch. That is nearly 4 hours more than the previous model. The cost is $1,150.Has anybody elas out there experienced a similar problem?
I would have never purchased a standard if I was told that the transmission would fail in 72K miles and it would cost $1,150 to replace.
$1150 is bad, but not anywhere near the cost of replacing an auto tranny (for example, $1600 for my '90 Sable way back in 1996).
Also, on my first new car, a 1975 VW Rabbit, the clutch failed at only 13K miles, and I learned to drive on a stick shift back in 1968, so it wasn't that I didn't know what I was doing. And it wasn't covered under warranty. As a poor graduate student, I wasn't very happy!
Just a thought: have you priced the work at an independent shop? My Sable was done at such a shop and cost $700 less than it would have at the place I normally go for service work (also an independent). I wouldn't trust national chains like AAMCO, and I only go to the dealer for warranty or recall work.
i agree with you, drinkwaterxyz should consider looking for an independant specializing in toyota repairs to see how the rair and parts costs would compare.
Persistence will overcome!
jon
