2001 montero sport XLS 3 0
montonfused1montonfused1 Member Posts: 2
edited September 2017 in Mitsubishi
2001 monter sport 4x4. I have replaced fuel pump' wired directly into battery with 20amy online fuse and on off switch. New tps new cam and crank shaft position sensor along with fuel pump and injector relays. Throttle body and egr have been cleaned also. It will start with starting fluid but won't stay started even with pump on pumping fuel. Any one have seem advice? I don't know much about mistubishi.
  • montonfused1montonfused1 Member Posts: 2
    I'm not sure if it a ground problem or the way I wired the power for the pump.
  • Do you currently own a Mitsubishi vehicle? If so, a reporter would love to ask you a few questions. Please send a note to PR@edmunds.com by end of day Thursday, November 30 if you'd be willing to chat. Thanks!
