smelly vent
Whenever I turn my fan on, the air smells
like old laundry. Is there a way to clean
the vent? I have '96 integra.
Your dealer probably has a pretty good fix...sometimes a spray like "OZIUM" works, but sometimes if it persists, you need to towel out the vents and that may require some disassembly. You need to get that crude out of there somehow.
You might also give a call to Acura customer relations. Your dealer has the number.
http://www.alpineindustries.com/
We have a "living air" machine, and use it for everything. It eliminated the smoke smell in our basement in 1/2 hour during the salesman's demo, so we bought it. Frying in the kitchen? We run it to eliminate the smell. Turned on the furnace last week. Pointed the air cleaner into the furnace intake to eliminate the initial burning smell.
Smells in the air are due to active substances. Ozone, O3, is very reactive, and reacts with these substances to eliminate such problems.
Sorry for the commercial guys. No I have no stake in these things.
I did see one article on the net on how Canada's health agency recommends to NOT use these things. High levels of ozone are dangerous, keep that in mind. I am careful to turn it down if anyone smells ozone in the house, and it has EASILY solved numerous problems, so we don't worry about it.
guitarzan
Community Leader/Vans Conference
I have tried spraying Lysol into the vent intake. I think my owner's manual even recommends this. It may help somewhat. I also try to dry the ducts out whenever possible by running with the A/C off. This probably helps a little bit. The problem hasn't gotten out of hand yet on my current car, but I'm afraid it's just a matter of time. Yesterday I bought a can of "ozium" and am trying this currently (I won't really know if this makes much difference until next summer).
One really interesting thing I read about yesterday at TheCarConnection.com (mechanic section) is that GM supposedly offers an "after blow" kit that works by running your vent fan for a period of time after you shut off your car. The idea is to dry out the ducts to keep growth down. Sounds like a fantastic idea. Make one for my Ford and make it affordable (and simple to install)!! This seems like a real solution.
Car makers: are you listening. I don't want a TV/VCR in my car or satellite communication. I just want the fan to blow for a few minutes after I park. How hard can that be? One of your college interns could design that in during your coffee break.
I think it is truly unfortunate that cars are designed and built by people who live in cool climates (Detroit, Germany, etc.). We don't need your seat heaters, block heaters or headlight wipers, thanks anyway.
I'll keep you'all posted if the ozium helps or I learn anything else.
Good luck. Sounds horrible. :-(
If you have success, come back and let us know what worked for you.
Pat
The American Lung Association and the EPA suggest not using ozone generating air cleaners.
Yes they can work effectively, however, they should never be used in an occupied room. you won't die, but it can relate to health problems.
This makes it a BAD choice for a vehicle. Dealers or detailers can clean the vent/AC system to eliminate the odors.
But the WILL RETURN unless the source (pooling water or high humidity) is eliminated.
The next best "band-aid" would be a cabin filter with HEPA filtration and a carbon filter. These are not common accessories that I am aware of.
That is all for now...
So far as ozone is concerned, it also didn't work on either my 86 Taurus, my 98 Sable, or my 99 Sable. Where does one find "Ozium"? I'll try anything, at this point, because it looks like Ford isn't the only one with the mold problem. Maybe with monthly applications of it, I can stay ahead of the problem. I can't keep taking the car apart each month to clean all surfaces. Why are all these mold problems occurring, anyway? Are they something new due to new materials or designs?
Guitarzan
I must admit I am more sensitive to mold than most people I know with allergies. The bottom line is that although my husband isn't bothered at all by my car, I am the one who drives it so it is now for sale. I give up. Anyone want a good deal on an excellent car? Merc Sable LE Wagon for $17,200 with every option except CD. 19K.
Saw on one of the tv car programs (Motorweek I think) where they used a disinfectant foam which was pumped throughout the entire air vent system. This supposedly worked for them.
I don't know why this doesn't work. The machines are producing ozone, right? Nasty smell?
I just remembered, we used the machine at sister's house. Water running down basement walls. A whole wall full of mold. Machine killed it all. Hmmmm....
Guitarzan
People like these things because of the clean "smell" of nascent oxygen. It is dangerous in my opinion.
In the summer when I start my AC on my honda-it reeks-that blast of stuff has a lot of mold in it-it too can be very bad for people with respiratory issues or allergic reactions. Found if I turn on the heat just before I shut the system down and dry it out-helps.
good thing it's not very likely to be your problem.
Guitarzan
Any ideas? Any others out there? I'm looking for others with the same problem to form a class-action team.
http://www.DWD2.com
for solution to smelly a/c vents.
To Clean Air!
You have a good point, although your post seems a little misleading. Ozone IS dangerous to people's health. It takes the kidneys great effort to clean ozone out of our bodies.
I am NOT saying the ozone machine is the best solution for water in the vents. After all, the moisture might come back daily depending on the weather, type of car, etc. However, an ozone machine can be used to rid any area of any offending smell. The procedure I would use: Close all windows, put machine inside vehicle, and turn on full blast. Leave it there for 1/2 hour-1 hour. Open vehicle up completely, and air it out. Ozone will stick to the fabric somewhat, so when first driving, open the sunroof, turn on the vents, open the windows, etc. to air the vehicle out thoroughly. Once the ozone is gone, it poses no health risk.
O3, or ozone, is extremely reactive. Any active substance will combine with the ozone, forming O2 (oxygen) and harmless particulate matter. Then, like I said, the extra ozone should be aired out and not breathed in!
You may be right that ozone doesn't kill bacteria. I have no idea about that. All I know is any time we have an offensive smell around our house, we put the ozone machine in the area, turn it on full blast, remove it within an hour, and air the area out.
I do know that at some medical facilities they turn these things on, and leave a concentrated ozone spread throughout people's living quarters. This is plain DUMB, and serves NO purpose, other than to potentially damage the kidneys and poison-removal bodily systems of those people around it.
Your symtoms may be from the mold.
Nissan (Corp) inspector could not smell it and say there's no defect.
Domino8, stinking in Mi too, riolomas, staff2, I suggest you do what I didn't. If your car is under warranty, take it in everyday for the smell. You may be able to get it replaced within the first 12 months or 12,000 miles. But you must follow your state's lemon laws (you can find on computer).
Action is key! Keep taking it back to dealer. I'm out of time on my 12 months and nothing was ever recorded to be wrong on service records, so they think I'm a pain in the butt.
I'm suggesting people not buy 99 Altimas and hope no one else has to go through this. It's so frustrating!
Lawyer said certified mechanical has to sign statement and testify to take action and what good is 1 person against Nissan?
So, I'm stuck. Hope to trade in before 3 years are up because windows are rattling now.
Good luck to you. Remember to keep taking it back and get what they did recorded on your records and theirs.
Quick bad-smell-horror-story: my uncle in England had a Citroen that had the air vents between the front seats, (go figure, my brother had a Renault with a manual stick shift that you pulled and twisted out of the center of the dash!) Anyway, new puppy, car sick, dog vomit in heating vents, smell there for years.
Jonty
then the smell only last for a couple minutes, but
if you turn the A/C off and just run the outside
vent, then the smell is constant and does not go
away. This problem started at about 20,000 miles
and the dealer installed an Electronic Dryer Module which cost GM Warranty about $800. I found out that there was a GM Service Bulletin out about
this problem and it required installing this module so I passed on this information to the dealer and they did it. This helped for a couple monthes, but now the problem is worse than ever and the dealer has been unable to fix it the last couple visits. Last time they disinfected the A/C, but this did not help. They said this was common on the Buicks and thought this would solve the problem. Has anyone else experienced this smell from the vents? Any ideas on how to solve it? We now have about 35000 miles on the van and the warranty is about up. This has been one of the many problems this van has had and we have been back to the dealer over 15 times for different repairs. I have listed them under the Topic "2000 Montana". I live in NC where the humidity is bad.
Matt
I finally got her out of that habit with the Explorer, showing her the recommendation from Ford. I then used a trick that I saw on the evening news. Spray Lysol into all of the vents to kill the mold. Her Explorer is now smell free.
2. Efficency is further improved by keeping the blower velocity as low as functionally possible. The slower the air moves through the evaporator vanes, the cooler it becomes.
3. Many new cars have variable levels of flow-through (new intake air), RECIRCULATED air often does not need to be heated or cooled as much as incoming outside air. In automatic mode most cars modulate the amount of incoming airflow.
4. Many manufacturer's signed on to NipponDenso, Denso USA's practice of embedding an anti-microbe chemical within the evaporator, this was done by attaching a porous nylon material to the vanes of the evaporator into which the chemical was "soaked". Once the chemical was all used up these nylon pores becames an excellent storage place for the cool moisture molecules which promote mold and mildew.
5. In older vehicles, and in many newer vehicles such as Saab, the A/C compressor was not allowed to operate below about 45F. Then someone decided NipponDenso again?) that the A/C could be used below this temperature to help defog the windshield, IF (DAMN BIG IF!) the system could be made efficient enough to actually extract (condense) moisture from incoming airflow that was already cold.
2. If you are able to do so, open as many windows as possible when the car is parked, expecially overnite.
3. Always use HEAT and flow-through ventilation mode to defog the windshield, and to dehumidify the cabin atmosphere, especially when temperatures are below 50F.
4. Running the system on MAX HEAT, MAX blower and FULL recirculate mode (the A/C evaporator is upstream of the heater core, INCOMING outside air would not be heated)for a few minutes after the cabin becomes uncomfortable before shuting the vehicle down for the evening will certainly help.
5. For those of you who still insist on using the A/C to dehumidify the cabin or defog the windshield please remember that by design, THERE IS NO EXISTING SYSTEM THAT WILL COOL THE EVAPORATOR BELOW FREEZING, and most cease to operate the compressor altogether below about 35F.
If you drive into a climate wherein temperatures decline below this level the dehumidification capabilities of these systems will become nill. What is even worse is that the moisture previously condensed onto the evaporator surfaces will then begin to evaporate into the incoming airstream, sometimes rapidly so.
So, be REALLY careful out there!
