What could this be? 2007 mazda cx-9
baldman1baldman1 Member Posts: 2
edited December 2017 in Mazda
my park lights will not work in my 2007 mazda cx-9 but my hazards and turn signals do work fine. What could this be?
Answers
  • thecardoc3thecardoc3 Member Posts: 5,862
    Complicated. First does the car have auto headlights? The INS relay is either directly controlled by the headlight switch with manual lamps or by the automatic light control module with automatics. You could check to see if you are getting power to and through the tail lamp fuse in the fuse block on the passengers side of the dash, but that goes to the body computer which then powers the lamps from that point. You really need professional level scan tool support to go beyond this point. If you don't have a regular shop use the iATN shop finder to locate a technician near you that can handle this. www.iatn.net
