Reprogroming my 2016 Elantra Gt Remote
I recently tried to start my car remotely and it didn't work;so I guess I must Reprogram it to work. I have all my car manuals and couldn't find much to help me. I have the six button fob, I tried to get the Remote Starter to work by first pressing the "Lock Button" then the "Key Button" the car horn blew (3) times along with the lights flashing (3) times but car would not start. Also, I have searched the Internet and found nothing helpful. Is there anyone that can help me
Answers
If your fob has a red triangle button on it, then the button under the dash should be there.
If no red triangle button on the fob, you're more than likely going to need to go to the dealer.
If you can find the bell button (again, that is IF it is there on your vehicle. Some don't have it)
With the key on and engine off press and hold the button in for 15 seconds and the horn will beep, that puts it in learn mode. Press the lock button on your remote and hold till the horn beeps again. After the remote is programmed turn off ignition.
