fredly:
That "1,000 mile" FMC e-mail that you received was probably one employee's opinion, not FMC's position. I'll save my time and money and follow manufacturers' published schedules. I've put lots of miles on lots of cars and have never experienced any oil-related problems following the book.
camelard:
Clearly, more frequent oil changes won't do any mechanical harm. But don't worry yourself about unneccessary maintenance.
Granted that they are not looking at the "break in" period, it is becoming widely accepted that the oil change interval is well beyond the Jiffy Lubes of the world's 3k as well as outside that of even the manufacturers' 5k interval, regardless of lubricant type. I have been told by those connected to the industry that the manufacturers' intervals will be going up significantly in the near future (using synthetics, naturally).
In short, balance your wallet, manufacturer's maintenance schedule, conscience and wealth of information available to you to make the decision that is best for you and your vehicle. You would go nuts trying to find the "right answer".
"Hell I just bought a ~18K car, I'm gonna take care of it whats 20$ for a little preventative
maintenence(even if its not recommended)"
Better safe than sorry (IMHO)
Skip G.
I actually got a curtsey call from the service department last night. They wanted to know how the V2000.98.22/sub84-33-badulah:nostall software was working.
V2000.98.22/sub84-33-badulah:goreallyfrigginfast 4.0 software.
Bad:
After you've done the Beta Testing of this new software, let us know how it works and make it available tothe rest of us!
Skip G.
that are available in Edmunds about the cougar so im familiar with everyone.. Hi! - I just got the 2000 V6 and love it! Just wanted to check in, say hey - and be in touch!
Scott
Don't worry, no one's going to laugh John, a Cougar is always welcome, no matter the configuration.
You might also want to check out the Zetec (I4) specialists at: http://www.dunnell.co.uk/
Good luck!
Congrats on your new purchase and welcome to the CSG!!
johnluciano:
There is also a short throw shifter available for the Cougar which can be found on www.nopi.com
Both of these mods should clean the shifting up nicely.
Rob
AKA "Badulah"
http://home.att.net/~cougarsupportgroup
pretty tough to find, the silver frost, v6, and
5 speed - I live in Ohio and the dealer said this was the last one in a five state area, they found it in Kentucky -I'm not sure if its true, does any one have any idea how many 2000's are left? Were they not pulling my leg?
I saw a few posts, but just to make sure, the rev limiter is set for 6800? I've got 600 miles on it, and plan to do conventional oil at 1,000 miles(for good luck) - conventional oil at 5,000 - and probably go with the synthetic at 10,000 and beyond.
Do you plan to attend Cougar Fest Y2K on September 16th? Since you live up that way it won't be that far of a drive.
I've got the I4 also. For me, the smoothness of the shift depends on the engine rpm's. If you shift around 3000-4000rpm, it is alot smoother. Anything less, and anything more is just too jerky. But then again, I guess it also depends on the drivers shifting skills
not too far from me... be a fun drive for the
Cougar..
If you're coming, don't forget to register.
Skip G.
John
John
1. Driver side weatherstripping came loose
2. Cat pulls to the left
3. "Factory" wrinkle in the right quarter panel and bumper.
4. A/C blows hot
6. Trunk wouldn't open right
PS: Trunk STILL doesn't open right!
-John
After 4 tries, my trunk works 90% of the time, and all the A/C needed was the proper level of charge.
Hope this helps.
Skip G.
I think you're on the right pro-active track in taking these steps to avoid paint contamination. Although I am not sure what any of those harsh insecticides may do to paint, I'd worry all the same.
I suggest to just keep doing what you're doing, as a car cover (unless you really want one anyway) doesn't keep dust out, only rain and grime for the most part. Also, if there are any contaminates on the paint before you cover your car, they might engrain themselves into the finish while covered.
Wash ASAP aftrer spraying, should be OK.
At one time, they used to use kerosene & DDT. Now that could get corrosive.
Skip G
TSB #12707
R1995-1999 Contour/Mystique/Cougar front brake groan
Some 1995-1999 contour/Mystique and 1999 SVT Contour and Cougar may exhibit a front brake groan. TSB 99-08-09 (front brake groan during city driving) can also be applied to the 1999 SVT Contour. However, this TSB should only be applied to Contour/Mystiques/SVT built before 06/1999 and for Cougar built before 05/1999. Vehicles built after these dates will already have the new front linings installed in production."
TSB #13900 :
"Rear brake grind/groan on first application after
parked overnight
Some 1999-2000 Cougars equipped with 4-wheel disk
brakes may exhibit a groan/grind noise from the
rear brakes on the first application after the
vehicle has been parked overnight. This noise is
unrelated to braking performance. Servicing the
rear brake pads and/or rotors results in little
improvement at the present time. Engineering is
developing a service procedure for this noise."
TSB#13974
"Brake pad wear sensor
When replacing front brake pads on a 1999 Cougar equipped with sensors, the sensor harness on the service part pad being installed on the right front brake may be cut off and discarded. The pad wear sensor system monitors only the rear brake pads and the left front brake for wear. Removal of the harness will not affect brake operation or pad warning lamp operation."
TSB#????
I was only able to retrieve this partial wording:
"... applications. To repair, replace the rotors with a non-dacromet rotor part number F8RZ-1125-CA and replace the front brake pads with P/N XS8Z-2001-DA (w/pad wear sensors) or P/N XS8Z-2001-CA (w/o pad wear sensors). Retest to verify repair. Note: This repair will not resolve brake grind noise concerns. Engineering is currently developing a repair for the brake grind issue and a TSB will be published as soon as a service procedure becomes available."
Any ideas, suggestions?
For leather care, I suggest Lexol I believe it comes in a tan and orangish bottles
Cleaner and Protectant... smells great isn't slippery and makes leather nice and soft.
Should I remove all waxes/glazes first? Do two coats and a sealer top coat like I do with my nail polish?
All help greatly appreciated!
There are some companies that come to your car, and use airbrush for minor nicks and scratches. If they're any good, the finish should look like new when they're done.
Check the phone book for one close to you, and ask to check out thier work on other customers.
Skip G.
Sorry I didn't get to say good by to you and your wife. I kinda ran out the door in a hurry. It was nice meeting the both of you. Hopefully next time we will have more time to hang out and shoot the breeze.
Ford Motor Company will issue a safety recall concerning certain 1996 through 2000 model year Contour and Mystique models and 1999 through 2000 model year Cougars for a possible brake defect.
The vehicle's Brake Pressure Control Reducing Valve will be replaced under safety recall number 00S03. According to Ford, "on some of the affected vehicles, one or both of the brake Pressure Control Reducing Valves (PCRV) may malfunction due to corrosion. If both PCRVs malfunction, both rear wheels may lock up when braking, potentially resulting in loss of control."
The recall will include the following vehicles:
* All 1996 through 2000 Model Year Ford Contour and Mercury Mystique Vehicles without Anti-Lock Braking System (ABS) with build dates 4/1/1996 through 2/4/00 at the Kansas City Assembly Plant and build dates 4/15/96 through 2/18/00 at the Cuautitlan Mexico Assembly Plant.
* All 1999 through 2000 Model Year Cougar Vehicles without Anti-Lock Braking System (ABS) built from Job1 through 3/16/00 at Flat Rock Assembly Plant
Andy.
Skip G.
This leads me to think that there is a great demand for trans or none at all. What do you think?
There were only a few TSBs for Cougar transmissions. The folks posting on this site didn't have any significant problems with them. You might ask your dealer's service department manager to review this Technical Service Bulletin:
Service Bulletin Number: 0019
Bulletin Sequence Number: 122
Date of Bulletin: 0001
NHTSA Item Number: SB612301
Make: MERCURY
Model: COUGAR
Year: 1999
Component: POWER TRAIN:AXLE ASSEMBLY
Summary: INFORMATION REGARDING SEVERAL INTERNAL CHANGES THAT HAVE BEEN IMPLEMENTED ON THE MRX-75 TRANSAXLE TO IMPROVE SHIFT EFFORTS. *MJS
crighto
Skip G.
