2012 CRV compass calibration - Help!
phopho Member Posts: 13
edited February 2018 in Honda
My car's compass will start the calibration every time when I start my car.
Best Answer
Answers
  • phopho Member Posts: 13
    I need help for the compass problem
    My car's compass will start the calibration every time when I start my car. Anybody had the same problem? I could not find no answer.
  • thecardoc3thecardoc3 Member Posts: 5,858
    edited July 2018
    I first considered that you might be losing a keep alive memory power to the compass module, as I was doing a little research to see if that was plausible I found this in Honda's service information.
    The electrical compass unit has a self-calibration function. It detects and compensates for
    magnetic anomalies caused by magnetized tires, bridges, subways and large steel structures.
    When the vehicle leaves an area with a strong magnetic interference field (2,400 mG or more),
    the electrical compass unit automatically begins calibrating after it receives the VSS from the
    PCM. If needed, you can manually calibrate the compass.
    Which leads to this question, does it do it every time you start the vehicle or only when you park in specific areas?
    edited July 2018
    @thecardoc3
    I tried manual calibration many times and didn't work. Now every time when I start my car the compass starts calibrate itself.
    Diagnostics are limited to testing powers, grounds, and serial communication. From there it's replace parts.
