Charging problems
Hi I'm new here so I have a 2002 Kia sportage that is having some charging problems. Bought a new battery and found it was the alternator. I've changed the alternator about 3 times now and it goes for a little bit before it dies. I have cleaned all the grounds and the battery connectors. Now I'm at a lost
Is the charge lamp on when you turn on the key without starting the engine?
If so, does it go out after the engine is started?
What is the battery voltage with the key and engine off?
What is the battery voltage with the engie running and no accessories turned on?
What is the battery voltage with multiple accessories turned on?
Make those checks both at idle and at 2500rpm.
