2005 Pontiac Bonneville - "check gauges" flashes and the annoying "ding-ding" keeps sounding
replaced the "anti-lock" sensor. Want to stop the buzzer sound
Best Answer
imidazol97
Member Posts: 27,736
What "anti-lock" sensor did you replace? I'm not sure what you did?
Read the codes. Is there any gauge that is reading out of range?
Check the battery. How old is it? Check the ground connection from the battery to the rear floor. I'd suggest disconnecting the battery for a while and cleaning the metal at the ground connection.
5
Answers
