Subaru Crew - Modifications
18911131431
  • alingaling Member Posts: 598
    I agree as well. I'd be careful about using such low profile tires/wheels off-road. You obviously want a reasonable amount of sidewall for cushioning.
    BTW, you can also lower the tire pressure slightly while off-roading. This should give you a smoother ride. Just don't lower it too much or you might run into trouble with the wheel coming off the tire. Also, steer your sidewall (weakest part of the tire) clear of objects. You want to roll over the obstacles with the strongest part - the steel belted threads - of the tire.
    Drew
  • kenskens Member Posts: 5,869
    juice -- Good idea. I'll take some photos after I wash the Forester this weekend.
    Dave -- My brother owns a Passat and he went from a 16" to 17" wheel. According to him, the ride didn't suffer very much while handling improved quite a bit. Be aware that the 17" rim will take a lot more beating on rough roads however. My brother lives in NYC and he's had to replace 3 out of 4 of his rims because of potholes. I would stay away from them if you do intend doing some rough stuff.
    However, if you're staying on the road, going with passenger car tires is not a bad idea. There are tons more choices with passenger car tires, especially to fit big rims and low profiles. If you look at the tread pattern on the stock Bridgestone Duelers or especially the Yokohama Geolandars, they are fairly close to all-season treads vs. all-terrain. It's probably more marketing than necessity that they use light truck tires.
  • subearusubearu Member Posts: 3,613
    Thinking of ordering this from QSubaru.
    I was wondering if anyone had this thing installed - or installed it on their own. How does it connect to the hood? Easy to DIY? No drilling?!?!
    -subearu
  • 2ndwnd2ndwnd Member Posts: 145
    Anyone know about the feasability of putting an aftermarket sunroof on a 2000 Legacy/Outback Wagon? Up front where it would normally go, the roof is not flat. If it had to go where the roof is flat, it would be more over the rear seat, and also the dome light would have to be moved or removed. Do sunroof installers move dome lights or would that be out of the question?
    Dave #274
  • jrbelknapjrbelknap Member Posts: 15
    I tend to agree about avoiding the shorter height sidewalls for offroad, but I will say that I had Pirelli Scorpions on my Jeep Grand Cherokee in a 70 series and they were awesome on and off road. I wonder if they have them in the standard size.
    -john
    The dealer here in Redwood City (CA) has several Outback wagons with aftermarket sunroofs. As you say, it is a bit farther back due to the compound roof shape, but it is still efffective in making the car more "airy" feeling.
    The one concern I have is that there is a structural rib running across there - a continuation from the B pillars between the doors - hence the "rings of steel" that Subaru promotes, and I think that one gets cut out when the S/R goes in. May not be a big deal but it would worry me if that actually is a strengthening rib, and the car were broadsided. Next time I am in there I'll ask them about it.
    -john
  • dzartmandzartman Member Posts: 112
    Thanks to all for the comments on bigger rims! I'm leaning towards the 17" with 55 series tires...as juice pointed out I lose .4 inch of sidewall, but I think that will be fine as long as I don't slam into rocks and such....which I didn't do even with my 16" / 60-series. see http://www.wave.net/diveguy/Dave for my Subaru page
    I've noted that rallyers use 17s with 55-series tires, of course this is mostly gravel roads and dirt that is smooth.
    Has anyone gone to http://www.spdusa.com/prod03.htm
    where Mike speaks very highly of the 17" Speedlines as unlinely to ever bend, and he has 87000 miles on them.
    also
    http://www.spdusa.com/tires.htm
  • guttermouthguttermouth Member Posts: 10
    Doesn't the Impreza RS/LX AWD come with regular car suspension? Can you rally style off road with stock suspension? I thought those rally cars had special super strength suspension to handle off roading.
  • p0926p0926 Member Posts: 4,423
    Juice - I was planning on waiting until B-day in Sep to get a digital camera but may have to get one earlier to show off the tint job on my Blue Ridge Pearl Forester S.
    All - Got a set of Hella Twin Supertone horns (OE horns are way too wimpy IMHO). They're definitely louder but not by as much as I was expecting. I'd say they're roughly comparable in volume to horns of the 60/70s. Unfortunately the install isn't for DIYselfers unless you're pretty good at electical wiring. FYI: I got mine installed in a way that allows me to switch between the OE horns and the Hellas.
    - Frank P.
  • locke2clocke2c Member Posts: 5,038
    About the impreza/forester/obs, the front suspension is designed to bend to prevent the chassis from bending or the strut from breaking. (specifically the control arm-- there's only one, unlike most cars and it is lower)
    However Speedlines can and do bend. Here's a discussion about them on the iclub:
    http://www.impreza-rs.com/NonCGI/Forum1/HTML/010525.html
    But the folks that bent them were running 40 or 45 series tires so you should be reasonably safe with 55 series. But still, toss a small grain of salt when reading Mike's work even though he is well respected. My main complaint about SPD is that his technical topics have (mostly) not changed at all in the 2 - 2.5 years of Impreza tuning development. We've learned a lot, but he hasn't put up anything new.
    -Colin
    Wow, and I thought my highway blaster was a step up. Way to go.
    guttermouth: the RS is lowered and has very low profile tires. It would be like a fish out of water off road. Try a Forester or Outback, at least.
    Dave: the WRC team uses different tires depending on conditions, but I don't think they're 17"ers. I recall one set being a surprisingly small 205/65R15.
    Ken beat me to it, but last night I thought about bent rims as well. Just make sure they're strong, at least.
    Also keep in mind the tread pattern on a 55 series tire is going to be pretty much the opposite of what you want off road. Unless you get an SUV tire in that size.
    Why not two sets, though? You already have the 16" alloys, it'd be a shame if they went to waste. Or would you sell them?
    Sunbeam: the deflector should be easy to install, and does not require drilling.
    As for aftermarket moonroofs, yes, the installers may have to remove the B-pillar bracing. But they do add their own bracing to compensate. Models with the OE moonroof also lose this bracing, like the Forester S Premium and the Legacy GT and Outbacks LTD.
    -juice
  • ramonramon Member Posts: 825
    I think even an RS can handle mild off roads. Don't talk about crazy Acrapolis rally conditions. A few months back a few of us consisting of my OBS, my friend's TS and his brother's OBS took to some gravel roads and we were fine. No paint chip either! We made sure we were spaced out so that there would be time to brake if anything happens and to not catch any debris. It was alot of fun. However I don't recommend 17" with lowe profile tires though.
    Colin : maybe those guys who bent their rims took to the gravels on their low profile tires. Obviously it will destroy the rims!
    Sounds like fun.
    Dave's forays are pretty bold, however. That type of "road" in an RS would be crazy.
    -juice
    In tarmac trim the WRC cars actually use 18" rims, at least the impreza and lancer do. The maximum tire width is 210mm and they run that on tarmac, sometimes on gravel.
    In mud, ice and snow they run narrower tires. The snows in particular, they're like 165-175mm. But all the non-tarmac wheels are 15".
    If you want to do gravel work in a Subaru, buy some 15" wheels and some used rally tires. Shipping will cost you more than the tires in most cases, but they'll only last a few hundred miles -- much less if you drive them on tarmac at all. The impreza does fine in gravel with skidplates but obviously can't clear much of an obstacle and has poor approach / retreat angles.
    -Colin
    them about it.<<
    Could you also ask about the dome light, whether they move it back or just take it out altogether? Thanks.
    Dave
    They moved my dome light back. Works like a charm, too.
    -juice
    U can get them from tntracing. They are only used once. And can be had for cheap. I'd get 'em if I want to go rallying.
    BTW, I wonder can I use those for winter tires...?
    They won't last long on tarmac, especially if they are snow / ice rally tires. These things are super soft, for everyone that's never seen them.
    -Colin
  • qsubaruqsubaru Member Posts: 37
    it's because I'll be on vacation next week.
    I promise to answer all of it as soon as I return to work on 8-14
    Darlene
    qsubaru
    Have a good vacation, Darlene. We'll miss ya.
    -juice
  • kuttkutt Member Posts: 13
    Hello all! As others have said, your postings along with all the info at Edmunds.com aided me in my purchase of a 2001 Forester S Premium last week. I absolutely love it. Silverthorn metallic. Would like to know more about qsubaru@aol.com and the availability/pricing of accessories. From what Juice has posted and others it appears that many items are easily installed on our own. I am particularly interested in the tow hitch, brush guard and diff protector.
    Thanks again to all of you for the great info.
    Kutt
    Kutt: Quality Subaru is a dealer in Dandridge, TN. Darlene works the parts & accessories dept, plus warranty work. She sells at wholesale levels (often less than invoice prices for options) and includes free shipping. Just don't ask how she makes a profit, I have no idea.
    Have you seen her web site? I actually designed it for her. It lists the most common accessories, but she sells everything Subaru has to offer. In another topic she just posted the fact that she'll be on vacation next week, so keep that in mind if you don't get a quick response.
    I take it you've seen my full instructions for the hitch and the diffy shield, but make sure to browse all four pages (1 for the diffy shield, 3 for the hitch) to get an idea on the scope of the project. I took my less than a day for both. Make sure you have the right tools. A nice, big torque wrench is a must, preferably with 1/2" drive sockets.
    I don't have the brush guard, but I imagine it's not as hard as the hitch.
    If you have specific questions, feel free to e-mail me for more details.
    -juice
    (This may be a repeat post due to isp weirdness.)
    Colin, thanks for the URL to the rims thread. Seems like everyone is bending rims. I suspect it's pilot error in most of the cases rather than rims coming from the factory out of round, but who knows. Has anyone here actually purchased either Speedlines or Racelines and can comment on them??
    charm, too.<<
    Good! I was hoping I'd be able to keep it. Maybe this will work out then.
    Dave
    Yeah, it's further back so it lights up the rear seat nicely. That was a fortunate side effect - we have a baby and spills are common, so we love it. Maybe all Forester owners should have their lights moved back! :)
    The front still lights up a bit, and the map lights easily compensate.
    -juice
    Dave #415 (zartman):
    I don't know what was wrong with Scooter's Raceline RL-7's. I seriously do know some rally teams run them without incident. If anything I suspect they were mounted improperly.
    I'm considering them for winter wheels and his incident doesn't scare me. If I don't get the RL-7 (15") I'll get some of the older 15" Legacy GT wheels.
    -Colin
  • lwhittylwhitty Member Posts: 12
    I ordered this for my 00 OB from Darlene at QSubaru. The installation involves putting 3M protective pads on your hood in locations spelled out in a diagram, and screwing the deflector onto the hood with 6 minature rubber C clamps. No drilling is involved, and it can be removed without a trace. Took about 20 minutes to install
    I decided to install it after noticing chips in the hood after two weeks. Don't forget to order touch up paint as well, to fix any chips before you put the deflector on.
    The only downside of the deflector is that you can't go through a car wash with it on. Not a problem for me since I always wash the car myself.
    -Lee
  • guxxguxx Member Posts: 33
    Hi all. I am new to this forum. In June, I bought
    the new 2001 Subaru Forester S. All's great with
    it and I am enjoying it, which is a few steps up from my previous Plymouth Acclaim!
    I also had installed the bike attachment for
    the roof, but it is too hard to life my bike up
    there, so I don't know what my best option is: I
    could buy the side step rails but those are too
    expensive. I would like the rear bike hitch, but
    then I need the trailer hitch installed which is
    unncessary. So what if I get a non-Subaru trunk
    rack which has those tabs which slip under the
    door? Does anyone use those on the Forester?
    If I return the bike roof attachment, would the
    service department accept it? Give me credit or
    something?
    Not that it's a bad thing though when it comes to the WRX. I don't know if this is old news to everyone but I went to the Suby Sports webpage and they have a 2.5 RS turned into a WRX! Some guy must have lots of dough to spend/waste. It took more than 200 hours for the RS to turn into a WRX, but the cost wasn't mentioned on the page. How much do you think this would cost? Maybe the price would be so high it would be better spent on the Audi S4.
    I remember when I bought my MY2000 Outback that I didn't think i needed the All Weather Pkg...i was moving to sunny Cali and didn't need the heated gizmos. But the limited slip diffy...argh! $500 for that package but to buy one from Subaru is over a grand. Lesson learned.
    Nevertheless I was out on a GREAT rally road today. It's one of those roads built along the crest of a ridge...whew! Fun! Wishing I had the LSD, though. The wagon's understeer isn't horrible, but it's there. And without a bigger bar in back it's a tad hard to rotate.
    Both www.cobbtuning.com and www.rallispec.com offer LSDs, both front and rear. Any input on putting in a front vs rear, or front or rear only, how that would be? Mechanical LSDs are supoosed to be too harsh for street.
    I'm also sick of the lack of power. Is Ralliscpec ever gonna get that camshaft built? Has anyone had experience with Paeco products??
    Mechanical LSDs are supposed to be too harsh for street.
    Not true, but get ready for a really lengthy explanation.
    This is what a standard (clutch-type)mechanical LSD looks like:
    To the right of the ring gear is the clutch. The clutch type and number of shims determines how much lockup the LSD can achieve. 100% would be locked, essentially, as each axle will *always* be at the same speed. This would not be desirable for tarmac because when turning the right and left wheels want to turn at different rates. (or if it's a center diff, the front and rear tires turn at different rates)
    For a mix of street driving and performance on tarmac, a relatively low lockup of 20-25% is very common. Higher than that leads to trouble turning, wearing tires, and wearing out LSD clutches.
    Another type of mechanical LSD is TORque SENsing, it uses worm gears to detect slippage and locks the axles together. The gears can be chosen for a particular lockup but it can't be altered nearly as easily as a clutch LSD. Additionally, it only detects slippage under power, so under braking or coasting the handling characteristics change A LOT. This does make turning easier though around town. Quaife is a very popular reseller of torsen differentials.
    Viscous coupling LSDs generally lockup less than 25% and are slow to react compared to mechanical LSDs. On dry road they are often totally transparent as wheel slip is minimal (unless you have a LOT of power to the driven wheels). Offroad you have a lot more wheelslip and a VC can do its thing, but a high lockup mechanical LSD would be better.
    To sum up:
    Torsen = worm gear mechanical LSD, good for daily driving, excellent for a front differential (AWD or FWD), quick reacting, not easy or cheap to adjust
    Clutch = 'regular' mechanical LSD, sometimes bad for daily driving, excellent tunability, quick reacting, great potential offroad
    Viscous coupler = slow reacting, low lockup, good for daily driving, much better than open diff but low performance offroad.
    Hope this helps.
    -Colin
  • kate5000kate5000 Member Posts: 1,271
    No matter how much I play with seat adjustments, the driver's seat on my Forester'01 feels too short and my thighs do not have enough support. It's ok on short trips but on the long trips my right thigh muscle gets really aching, from accelerating/braking and not enough rest (no support) in between. I never had this problem in previous cars. I did not expect this, because I'm a short person (5'3), so the seat length and legroom is usually not a problem for me. My old Subaru'92 is very short-people-friendly: I had the best visibility and seat comfort there of all the cars.
    I wonder if there is anything on the market to improve the seat in terms of length and additional support. Maybe Darlene (QSubaru) knows?
    I'd be cautious about placing a LSD on the front wheels since they're what you use for steering. Turning the steering wheel could be tough in some situations.
    FWIW, the JGC with QuadraDrive + Varilock autolocking differentials has this kind of behaviour. When the front is locked or starting to lock, the steering wheel suddenly feels very heavy and difficult to turn. Rather disconcerting for someone who is unfamiliar with the vehicle.
    That's a truck though. Go drive an Integra Type R and tell me that you had problems turning. A torsen front differential is no problem at all.
    -Colin
    Thanks for the excellent post on limited slip diffys! It is helpful!
    Dave
    Kate- You're not the 1st to complain about the Forester's seats. However, it seems to be a very subjective topic since there are many others who aren't bothered by them a bit. I'm 6'2" but have driven 650 miles without getting overly fatigued by the driving position. If you really can't stand it though....it seems to me that you only have two choices:
    1. Buy an after-market seat (I.e. Recarro). But be advised that they're not cheap.
    2. Give up the Forester (NOooo!!!!). And an even more expensive proposition.
    Wait a min, just thought of a 3rd option....you can but a driver's seat cushion. I've got a friend who uses one in his 2000 Outback. It offers additional lower back and thigh support. Let me know if you can't find one at your local auto parts store and I'll ask the my friend where he got his.
    -Frank P.
    Regarding the car wash limitation: is that due to the brushes? Is a brushless car wash a problem?
    I have a 01 Forester that I'm ready to buy a deflector for.
    I've heard that the Forester's seat rails are intentionally shorter than the Impreza's. In fact, I know of some folks who install Forester seat rails in the Impreza to gain additional headroom (they're tall, or wear a helmet for motorsports, or both).
    Maybe you could go the other way. I think they had to lightly modify the rails though.
    -Colin
    My problem is not that seat is not close enough, it's that seating surface itself is too short...
    guxx: avoid the cheap trunk mounted bike carriers. I had an "Allen" carrier that let the bikes touch and scratch my previous car. On the Forester it would never get secure, so I gave up and got the hitch carrier. Shop carefully.
    Maxima SEs also have a front LSD, if you want to try one. Test drive a GXE and an SE back-to-back, to see if you notice a big difference.
    -juice
    Some observations about my mods. I met Hutch this weekend for Edmunds Live (see full post in the Meet the Members topic), and he has a 99 Forester S, so I was able to compare my rims and my hitch next to his.
    My wheels most definitely have a different offset. They're nearly an inch further out from the body. The outer treads have got to be 3 inches further apart, since the tires are also wider.
    The tires are also much taller. Not just 0.3", either. The difference is visibly noticebale, and our rough measurements confirmed this. Mine fill the wheel wells, his leave more space. Perhaps the Geolanders are small? Mine are 225/60R16 and his are 215/60R16, but the difference is bigger than the numbers suggest. Could it be because his are light truck tires?
    The OE hitch is impressive. The reciever is bigger and sturdier than his aftermarket Draw Tite hitch, though again, we forgot the tape measure. Also, mine hugs the rear bumper and does not affect the angle of departure, his does a tiny bit.
    I'm very happy with my mods :)
    -juice
    PS Read my reviews - the Forester handled the off road course just fine, thanks, and simply spanked the SUVs on the pavement section.
    The hitch is actually a class I with a 1.25" receiver. It's rated for 200 lbs tongue weight and 2000 lbs towing.
    -juice
  • bykstonbykston Member Posts: 2
    a silver 1997 Legacy 2.5GT Limited. Everything's great and I absolutely love it. I just have two minor problems with the car...the horn and the lights. If I could just improve these two areas, the car would be perfect.
    1)THE HORN: I don't really know if subaru uses the same horn throughout their lineup, but the one on my 1997 Legacy is aweful. I am embarrased to even sound the horn. Has anyone replaced it? Or can it even be replaced? I would much rather have something that sounds deeper and much louder.
    2)THE LIGHTS: I would really like to replace the lights. I dont want to make it look like i have HID bulbs, I just would like better illumination (brighter and better range). I've read all the previous posts about the SuperWhites and Cool Blues, so I dont want to start the same kind of discussion. I am looking for mainly personal experience...what have you used and how well has it worked?
    Any information is greatly appreciated. THANKS!
  • nypdaunypdau Member Posts: 38
    Soon to be owner of Forester S..just wondering what the benefit of a strut tower brace is? And how easy would it be to install?
    bykston: changing the horn is easy as pie. I got a "highway blaster" from Pep Boys, and it took 15 minutes or so on my Forester (it's behind the grille). I imagine it's similar on the Legacy.
    It's a tiny bit louder, but only slightly deeper sounding. Still, worth the $10. If I could do it again, though, I'd search for something deeper still, with more of a "honk" sound.
    Someone installed one of those fancy dual horn types, but had to get a dealer to do the electrical work.
    NYPD? Cool, I'll send a pat on the back for the tremendous improvements in safety over the past few years. Way to go.
    I have the metal strut tower brace, and I'm happy with it. It reduces play in the steering, and firms up the front a bit. I installed mine at about the same time as my new rims/tires, so it's hard to say how much they helped handling. But I can say I can take turns now at much higher speeds.
    Here's a photo. Install is so easy, you'd take more time putting cuffs on a perp!
    -juice
    PS It's $113 from QSubaru, and yes the Impreza SPT brace fits the Forester
    IMHO, you don't need a front tower brace. it's purely cosmetics. (sorry juice). Reason being that the front shock towers are situated so close to the already strengthened firewall. You are better off putting a rear tower brace b/t the rear towers for increased sturctural integrity.
    bykston,
    I would recommend trying the Hella Premium Xenon bulbs. I have them installed in my Forester and they are brighter than standard halogens.
    Here's what they look like:
    You can read more about them at:
    http://www.edmunds.com/edweb/editorial/innovations/xenon.html
    And I ordered them through:
    http://www.catalog.com/susq/hella/bulbs.htm
    Basically, these bulbs use some xenon in their gas mixture to achieve a brighter burning filament. These bulbs are good for folks (like me) who simply wanted a brighter bulb without going to higher wattages.
    The Cool Blue and Superwhites you mentioned are based on this technology but they are more targeted to people who want a "whiter" light similar to HID lamps. They basically are the premium bulbs but with a colored glass/quartz housing which filters light from the lower end of the spectrum.
    Ken
    ramon: no offense taken. On my web page, I admit what I like most about it is that it "looks cool". I don't AutoX and got the rims/tires at the same time, so it's hard for me to measure the difference.
    Ken: how much were those again?
    You know I'm the gadget guru. I have to get those and some new speakers. Did you swap just the front pair?
    -juice
    I also recommend the Hella Optilux bulbs, which are just as good as the Hella Premiums (as far as brightness goes), but whiter. The M-class owners that have bought the bulbs have been happy with the improved night visibility. Prices are quite reasonable as well: http://www.rallylights.com/hella/optilux_bulbs.asp
    BTW, whiter light is not just for looking "cool". It really does make a difference in contrast at night. This is one of the reasons why HID Xenon lamps are so much superior (but expensive). Oh, and the 3X more light helps too :-)
    AFAIK, all of these bulbs have trace amounts of Xenon gas inside which allow them to burn slightly whiter and brighter.
    Drew
    Just basics, like a screwdriver and maybe a wrench. It's really quite easy.
    The thing about a plug like Colin suggest is that you'll have some leak unless you're real quick about it. Just make sure the hose is pointing upwards when you pry it loose from the old filter, so it doesn't spill gas.
    The pressure release is a good idea, too.
    Actually, it's hard not to leak some no matter what you do. The methods you suggest won't be strong enough for a tight seal.
    If you do leak gas, you may notice the starter taking a little longer than usual to start up. No big deal, though.
    -juice
