Visitor Agreement.
Brett
Ed -- Personally, I found no difference after installing my Amsoil filter. The snorkus removal did make a difference, however.
Brett -- Ah, something else that shiny to spend money on. Wise choice.
http://www.wave.net/diveguy/Dave
it's my Subbaru page. for the movie and slide show you'll need Flash 4
http://www.macromedia.com
dave
Can you tell me how you get the mudflaps on your car what with the skirts and all? Did you do some cutting for the front ones? Just curious.
-Colin
Drew
-Colin
headed to bed now, it's 12:30!
So did you buy some el cheapo flaps and cut them to fit? I still have my old OBS mud guards which has been taken out since I put on some side skirts. I can reuse the mounting bolds. hehehe... But my question would be did you make them from scrap rubber/plastic thingy or buy the standard flap and cut them?
If you have any ideas, please post their name or address, or even better, their website.
Colin -- Nice work around for those little plastic clips.
Ken
Buy the real rally flap material from Susquehanna Motorsports and I'll trace my mudflaps for you. The aluminum bracket is kinda nice and would be more difficult to fabricate yourself.
-Colin
Back to the silencer, but what did you use to cover up the hole in the fender before you got the plastic plug from Darlene? I've been trying combinations of cardboard and tape, but the tape adhesive keeps melting from the engine heat. Also, did you notice any performance changes with the hole covered/uncovered?
Ken
Performance is about the same whether using my shadetree cardboard plug or the plastic Subaru one. There's less noise as I said earlier.
I cut a piece of 2 layer cardboard (~1/4" thick) and put it in place with what I believe was ordinary scotch invisible tape. I taped three corners and one side -- couldn't tape the corner nearest the hood & bumper because of the shape of the fender. No problems with melting and it was 110 several days here in the Dust Bowl. I peeled it off easily when the real plug arrived.
-Colin
Its lack of height adjustment has started annoying me. I think its set way too low. I'm looking for something simple first.
If I have to I will order a second drivers seat.....but I really really really dont want to do that (spend that much).
North Ursalia just posted a link to his diagram of the STi flaps. I guess I'll use it's measurements.... whoohoo. now where can I get some pink LDPEs?
-Colin
Thanks for the tips on the Lexus RX300 (not 400 as I wrote) gold window tint. That is factory applied and maybe I can't find exactly the same thing, but most places only offer the brown/grey stuff. Maybe when I'm back from the BC Road Trip I'll have some time to pursue it.
Stephen
_frank P.
Stephen
..Mike
I was impressed by the results but frankly the $650 price tag was a deterrent. Trey reached a deal with the cam grinder and is able to offer them for $499, and is offering a further $100 discount to iclub members through 9/30! So now we're talking $399 for 14 peak RWHP and 19 RWHP at redline.
(yes, rear wheel-- Trey's test mule is RWD)
To install the cams you have to remove the crankshaft accessory pulley (among other things) so I went ahead and got an unorthodox underdrive pulley too. It's only money, right?
Cams take a few hundred miles to break in and then you have to change the oil to get the assembly lube out. So I won't be able to give WOT, rev-limiter bouncing results right away.
-Colin
Sweet! I've been reading about those cams on the Cobb Tuning webpage. Please keep us posted on the results.
Now, in order to do this, don't you actually have to take apart your engine and send Trey your cams? What do you do in the meantime?
Ken
I've been looking through the Haynes Legacy manual and you have to remove the valvecovers but you don't have to pull the heads off the block. You also have to remove all the junk to either side of the engine (driver's side= battery, washer reservoir, etc.) and remove the fans.
I'll be getting help from my dad and any friends that want to drop by and learn. We figure one full day, but I'm going to remove fans, etc on friday night and we'll have all day Saturday and Sunday just in case.
-Colin
Cheers,
WDB
(who can't wait for the post break-in report)
ramon, it's possible Trey got a look at a 97-up SOHC EJ22 cylinder head this weekend-- Geoff from the iclub (SabreLion) had his turbo OBS in there getting some TLC. When I called Saturday morning to place my order Trey said it was a bit of a mess, but I didn't ask what all he was doing.
-Colin
-Colin
Man I hope when Trey get to test the EJ22s soon.
Larry: the Subaru OE alloys are expensive. Even Darlene's prices were well above Discount Tire Direct's specials, and those were 0.5" wider to boot.
Ken: awesome instructions, thanks for sharing. A friendly rivalry? Nah, I'm glad to have someone else try some things first. Subaru's instructions are worse than IKEA's!
I LIKE the intake noise. Those graphs were great - the fender is about 10-15 degrees cooler in every circumstance. Big difference to me!
Lithium grease is great. I also have a spray can of the stuff. Works like regular grease except it's not petroluem-based so it won't hurt rubber or plastic parts.
Colin: you da man. Please take photos. New cams sounds like a heck of a project.
I'll be curious to see where you fall on the pulley debate. Some folks swear by it (Garry Grimes comes to mind), others have it and complain about dimming lights.
Tom: the Forester doesn't have a turbo, but it's already about as quick as the RX300, and handles better. It's lighter and gets better mileage, too. A Forester S Premium costs about $10 grand less and with that you could do some SERIOUS engine mods, even forced induction.
Plus, it would be cool to have a mod-freak with a $10k budget join the Crew.
-juice
-juice
PS Loosh: pulley - c'mon, I want to get more opinions before I decide.
I need to find the truth here before I go dropping another $200 on the car.
especially since I kind of quit my job today. "Loosh, GET OUT OF RETAIL NOW !" is, I believe what Mike Smith advised. Who the hell was I to argue? He seems pretty smart and all...
I also have been doing a lot of reading regarding the air intake systems and have managed to get myself thoroughly confused. Does K&N make a drop in filter for the MY00 or MY01 (I'm assuming the engines are the same)? If so, where might one be purchased online? Does Darlene carry them? At this point, that is about all I may do now. I've read about troubles with the MAF (I'm not sure, but I think our car has one) when the air intake system is modified. I like the looks of the cone air filter system, but wonder about how difficult it is to install correctly. Told you folks I had a lot of learning to do about mods and cars. Thanks for any helpful thoughts or advice.
bogusbob
I don't think your '01 RS has the MAF that causes problems, butI haven't been keeping up with that stuff much. All I know is my Phase I 2.5 DOES have a problem, so I am leaving it alone, other than perhaps pulling out my snorkus. Uh, huh huh, "snorkus," hu huh...
I personally wouldn't touch Midas
they screwed me over on my wife's exhaust, which lasted 4 months and they wouldn't take responsibility for it. That was back when I was a young pup though, so I didn't fight them the way I would now. Oh Well.
Glad to see you are also into the BMW CCA school thing. I am having a blast, although I might not have the cash for it for much longer. Are you taking your Soob? Are you in the DC area? I heard about a guy in the NCC CCA that traded off his bimmer for a 2.5RS while he waits for the next M3. Sounds suspiciously like you! If so, will you be at the 10/21 Summit Point school? FWIW, I have settled on a swaybar and links as an effective upgrade for the school and for auto-X.
Air filters: I know nutink
$225 for the custom exhaust sounds okay, depending on what kind of muffler it comes with. If it's magnaflow it might be kinda loud. The SPT/Brospeed exhaust is only slightly louder than stock.
-Colin
Um, Lucien, please walk up to Johns Hopkins (ka-plink, annudah link) and get your head examined. I meant, get the writing job first, THEN quit the retail job. My humble apologies to your mortgage company for the slight miscommunication. Drop me a line at the first homeless shelter that takes you. Sheesh!
A topic for discussion. Talk amongst yourelves.
Ok, I'll bite. HELLO?! Spock, explain!
Ken (bogusbob), What brand of helmet did you buy and what did you like about it? I'm in the market. TIA.
..Mike
I like Simpson safety products a whole lot. I would have bought a Bell Mag5 instead, but the LX8 was cheaper and lighter... unfortunately it's also taller and my head rubs the roof a bit-- damned sunroof.
Racer Wholesale has pretty competitive prices, but like I said you really should try something on in person first.
-Colin
