Are you (or someone in your family) a first-time car buyer who is struggling to find an affordable used vehicle? A reporter would like to speak with you; please reach out to [email protected] by 1/21 for more details.
2013 Forester Beeping
uicuic Member Posts: 1
edited November 2018 in Subaru
Over the last 2 days, I have a weird issue with my 2013 Forester. When I turn the car off and remove the key I get a beeping like the alarm system and lock system engaged but the doors do not lovk nor is the alarm activated. Anyone know what this means? The car and security system work fine. No burnt out head or taillight and doors are fully closed.
Answers
  • 93tracker5spd93tracker5spd North East Ohio USAMember Posts: 194
    Hello! could be a number of things, but before going to a dealer, the appointment, the waiting and so forth, I would try disabling the the beep system and rearming it, that might clear the hiccup in it. The procedure is listed below, rearm by running the same procedure again. Is also listed in the owners manual. Good luck.
    1. Sit in the driver’s seat and shut all doors and the rear gate.
    2. Press the “UNLOCK” power door lock switch.
    3. Insert the key into the ignition switch.
    4. Hold down the “UNLOCK” switch, pull the key out and re-insert it into the ignition switch at least 5 times within 10 seconds after performing step 2.
    5. Open and close the driver’s door within 10 seconds after performing step 4.
    6. When completed the turn signal lights flash
  • JustinLeadsJustinLeads DenverMember Posts: 1
    I am having the same problem. I tried the steps above but there was not flashing of the signal lights after multiple attempts at the process. Any other suggestions?
