p0a80 - code on Prius
stewstew Member Posts: 1
edited March 2019 in Toyota
what does it mean?
  • thecardoc3thecardoc3 Member Posts: 5,862
    edited March 2019
    P0A80, Replace Battery Pack.
    What it means is the state of charge of the battery cells isn't balanced. The system will allow up to a 20% imbalance, once that is exceeded that indicates that one of more cells are failing. The first data that I would be looking at first would be the ID numbers of the highest and lowest cells and the delta SOC (state of charge). Then I would be looking at the SOC of each cell, the resistance of each cell and then do a load test on the battery assembly.
    With that information I could then decide if replacing individual cells is a viable option or if in fact the best fix is to replace the whole pack.
    Under what conditions is this code setting?
