Problems with front end
AmberkinsAmberkins Member Posts: 3
edited March 2019 in Buick
Anyone know what might be causing a hard click or krunk sound when I turn right
  • imidazol97imidazol97 Member Posts: 27,763
    2 Bad sway bar link.
    3 Bad bushing on the A-arm.
    4 Bad ball joint.
    5 Bad constant velocity joint--should also cause noise when going slow especially when turning.
    1 Bad wheel bearing/hub. Check for play by raising vehicle and pushing and pulling straight in and out.
    Movement should be .05 inch or less. Sometimes this play is accompanied by a warning from the computer that the stability system needs to be checked, because the wheel speed sensing is affected by the movement of the bearing parts that shouldn't be there and confuses the computer.
  • AmberkinsAmberkins Member Posts: 3
    It's a hits a hard sound that I feel I was thinking tie rod problem
