Should I Fix Up or Trade Up My Old Car? | Edmunds
Edmunds.com
Should you fix up your old car or buy a new one? Here are the pros and cons of keeping or dumping, plus some signs that it's definitely time to move on to another vehicle.
Major repair cost can vary quite a lot between makes. For example, a head gasket repair on a Scion/Toyota 4cyl. is around 8hrs of labor. Where a Nissan 4cyl. is twice that in labor time for the same repair. Some cars just cost more to repair because they are harder to work on, which means more labor time.
Before buying any used car, I highly recommend getting a pre-buyers inspection. It will cost you a little up front, but could save you a lot more down the road.
coolant system flush
replaced rear struts
replaced front brake pads
replaced transmission seal/replaced fluid
replaced AC belt
replaced thermostat and radiator
replaced alternator
replaced timing belt
replaced water pump
replaced spark plugs and wires
replaced AC pulley
new tires
I've been told I need new CV axles and seals. And I'm due to replace the clutch. If I do repairs, I'll also get a new paint job, stereo and some other minor repairs. Here's my dilemma. I have $5,000 to spend. Should I get the repairs done, especially with everything I've already paid for, or invest that $5,000 in a used car? I don't have car payments now, and I'd like to keep it that way, so probably wouldn't spend much more than the $5000 on a used car.
My job situation is also very fluid with this national emergency.
Can I postpone the decision for now.
When I decide, should I fix or buy ?
I spent $20K+ on an Audi in the 80's, & lost big time. Since then I bought used vehicles (Toyota, Honda), and squeezed out every dollar out of them. Having less mortgage make me sleep peacefully at night than spending on a new car.
With many cars under my belt, I can honestly say if you have and older car that one has not been able to keep up with fixing the small items that can lead to larger problems down the road, that it is likely worthwhile to dump your older car and get one that is newer, because the overall repair of the car is just too much and the likelihood of throwing good money after bad...
Lately, I have been buying used cars and spending 3K to 5K on fixing items to make them reliable. If you find a car you like take it to a mechanic and see what the cost is to fix up the car to make it a reliable car with no maintenance necessary in the next 6 months. I will subtract that cost from the NADA cost of the vehicle assuming that vehicle is in good or very good condition. This is the maximum price I would be willing to pay for the vehicle...
Your financial situation is important as well... I own 5 cars because I have 5 drivers at it does get expensive. I put car reliability higher on my list than upgrading my home, so my cars are kept in reliable condition... If your vehicle is around town vehicle you can likely forgo some expensive needed repairs and run quite awhile with fixing your car when it breaks down... If it around the state vehicle, it is important to keep your eye on what needs to be fixed and priority of the work every 6 months or so... Try and budget and fix the most important items every six months. Budget for those repairs... For being able to take long roadtrips, you vehicle should have most driver items fixed and maintenance up to date.... Have your vehicle checked out within 3 months of a long trip to forgo problems on the trip. So when buying another car, ask yourself why are you buying the vehicle and why is it needed, and by the vehicle for that need. I have a Ford Focus Hatchback for driving in the city as a commute car, low cost of gas, and fitting into parking spots around town. It is not my dream vehicle but it fits the need and not the want.
