5 year unsolved engine problem
So ever since I owned my '07 I-6 DB7 it will "occasionally" only idle above 3,000 rpm's the engine quits if you take your foot off the accelerator. It will restart but you must keep the R's very high. It does not kick any codes. If you let it sit over night it starts and runs normally and my not do it again for months. When it does however there is nothing you can do except park it till it completely cools down. Been to the dealer twice - found nothing, been to local Aston guy.....can't find anything wrong. Love the car but don't trust it to get me from point A to B.
Answers
As far as conditions, it is almost always during a higher outside air temp, 80+. It does not seem to be electrical, it always has spark, so I'm guessing air or fuel. I can't tell however if it is fuel starved or flooded since I usually occurs in some place where parking is tough or I'm by myself and can't do anything but nurse it to the curb or roadside. I once let it sit for 5 hours thinking that would cool it enough.......but no. I had to Uber home and come back the next morning.
I was hoping to find someone that had experienced a similar problem and knew the cause & cure. There are just not a lot of these cars around.
Someone suggested disconnecting the battery when this happens for a few minutes and then reconnect and try to restart, I'm not sure what that would mean if it restarted and ran normally but it would be a good place to begin I suppose? Any thoughts?
What you need is an electronics/diagnostics specialist
One of the keys to this is I would preset (plan-out) the testing that I need to perform when the problem occurs. In some cases that could lead directly to the answer, but the expectation is to first identify the system involved in the failure and work from there. The main key here is I would keep myself ready to hit the road and get to the car the moment it acts up. By having the owner on a pre-planned route that usually meant five to ten minutes travel time. Once getting to the car I would perform all of the testing that could possibly be done out on the road.
